Deleting local variable collection leaves variables as selectable
Milliorn_Keleigh
When you delete a local variable collection, those collections are still available to select to apply to a layer. When the collection is deleted, those variables in the original collection should not be available when you’re selecting to apply to a layer.
Cameron_Collis
When I quit Figma and reopened the file. The used variables disappeared.
Celine_
  • 3607 replies
  • July 14, 2023
Hi @Milliorn_Keleigh ,
Thanks for flagging this. It sounds odd, I can’t replicate either.
Can you reach out to the team directly so they can try to replicate it: https://help.figma.com/hc/en-us/requests/new
Please use your Figma account email, include a quick screen recording of what you see on your end, the link of your file, and share it with support-share@figma.com invited directly as an editor (this won’t affect your billing at all).
Hector_Calaza
I have the same issue… have anyone found a solution for this?
Celine_
  • 3607 replies
  • July 17, 2023
Hi @Hector_Calaza , I can’t replicate on my end. Feel free to reach out to our support team so they can investigate further here: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001731233
William15
I can repro as well
MINKMINKs
I have the same issue…Try to reopened but not work
Sebastian46
Hi everyone, I have the same issue. 😕 even closing everything, once published there is no way back 😕 any solution to this? thanks
  • 26 replies
  • August 30, 2023
Same is happening here. any solution?
  • October 1, 2023
Bumping this up so the topic won’t close.
Nate_G
  • 180 replies
  • October 1, 2023
May be similar to this one around Modes and Variables still showing up even after a collection is deleted. I found a work around here: 🚨 Variables: Deleted collections and modes don't disappear - #18 by Nate_G
Andrea_R
  • 6 replies
  • October 19, 2023
I face the same problem 😕
I removed/detached all variables, use every command and solution suggested in this whole forum or elsewhere.
I even copied the library components into a new document, one component after the other. Eventually even detached the cleared components before copying into the new document. Still the ghost variable collection show up.
Celine_
  • 3607 replies
  • October 19, 2023
linked to this thread: https://forum.figma.com/t/variables-deleted-collections-and-modes-dont-disappear/47901/21 , workaround and follow up by Jacob Miller
  • January 17, 2024
