Control variant export naming (especially for icons)
  • 11 replies
When exporting variant names, the file name becomes a combination of all the variant properties.
There is no way to control the variant export name, which is especially difficult for developer hand-off.
In this example, I have a back icon variant group (Named “Back”) containing both an Apple and an Android variant of the back icon.
If I then go to export the Apple variant as an SVG,
The variant export name then defaults to “OS Type=Apple.svg”
Screen Shot 2021-03-11 at 8.35.40 AM
It would be even worse if I had multiple properties. For example, having two more properties could result in a variant name export as “OS Type=Apple, Direction=Left, Style=Line.svg”
This is a very poor naming convention, especially for icons. What I would like to have is the ability to control the name given to each variant export.
In the above example, I would like the Apple icon to export as the name “back.ios.svg” and the Android icon to export as “back.android.svg”. This way, our developers can export assets as needed directly from Figma without having to figure out what name to give each icon — further bringing together the designer/developer handoff.
Anyone else having this problem or have found a workaround?
Alyssa_Klein
  1. When exporting assets for dev teams, if I have an icon as a component, with variants, the file names are wild! I have to rename assets by hand and manually update the json files, or I have to detach the instance and rename and then export.
There has to be a better way.
Thanks!
Alyssa Klein
Product Designer @ Teladoc
  • 11 replies
  • April 8, 2021
Has anyone else cup up with a workaround for this?
Would ❤️ to hear from a Figma support dev!
Shane
  • 74 replies
  • April 8, 2021
Definitely a workaround, but I create an “export sheet” beside the component sheet. It has an instance of every asset variant I want exported on it, named as I want the export to be named. One pro of this approach is I often create two copies with different names (or folder path) and different export settings. So you get a folder of svg’s and a folder of png’s, for example.
Tina_Kim
  • May 13, 2021
Don’t get why this issue hasn’t gotten more votes!
Variants are awesome. But trying to mass-export them is another issue.
Right now, Figma doesn’t let you export variant assets with structural naming, which is a huge problem for our dev team right now. :’(
Hope this reddit thread helps you get a workaround.
reddit
Figma team, please have a look into this issue. 🙏
Lukas_Oppermann
Yep, big issue for us as well. It would already help if the main component (variant parent) name would be added
davemakes
Agreed. I really love the component variant system for working within Figma, and it would be great if I could configure exports to use the component, property, and variant names I’ve entered in a configurable syntax when exporting so that info is useful outside of Figma as well.
Jonathan_Roy
  • 5 replies
  • September 28, 2021
At lest include the component name (treating path elements as sub-folders) in the output file name for each variant. Otherwise, two components might very well have identical properties and values, and those would clash on export.
TEAM23_Design
This is a huge issue for icon exports.
Please let us configure the export naming somehow.
If the component is named ‘menu’ and the variant is Size=16, i would like some way to export ‘menu-16.svg’ for example.
Aleksander_Djordjevic
I’ve been using this plugin called Export Variants ( Figma - Export Variants | Easily export your variants to SVG. Figma variants are neat however they can be frustrating to ... ). It does a lot of what you are asking for here.
I still believe this should be handled natively by Figma, but it has been a good substitute for me at least
Vitor_Goncalves
This plugin is a major progress in this regard, but we can’t customize file names or choose to export in a different file format.
tamasratkai
Any update about this?
Danch
  • January 7, 2022
More of a workaround:
  1. move the variants outside from the main component.
  2. now you will have multiple components named something like main_component_name/variant_name.
  3. use Rename it plugin and choose 2.Find and Replace selected Layers.
  4. to Find add “man_component_name/”, leave Replace empty and click Rename
  5. now all components will have the clear name.
  • For multiple variant values you might need to do 4. multiple times to clean other //
Constantine_Zuev
On Mac you can use batch Rename to fix the names. Select all files then right click and pick Rename…
roge
  • March 31, 2022
Pretty cool workaround! I I made some changes by rename first property same as variant name. This has the advantage of avoiding conflicts with other assets prefixes when first property is the same.
Michele1
  • April 29, 2022
Hello guys. Any update on this?
I tried the two Figma plugins available (“Export Variants” and “Frame Exporter”). They do actually work but they apply only one resolution/format export mode at time. SO you are forced to do multiple export passes for each resolution and file format (I usually need to export 1x, 2x, 3x PNG + SVG) and adding custom suffix information. Totally unfeaseable for day to day jobs.
You got some news or update on this?
RJ_Clarke
  • 6 replies
  • May 26, 2022
Just here to say how painful this STILL is, even after Config updates.
Murat_Dincer
Having the same issue and our developers are struggling with this a lot. Hope to see a solution soon.
Stephanie_Preuthen1
Same issues with our devs, Figma please fix this. 🥲
Sam_Kim
  • September 7, 2022
same here. why should I use figma if I have to rename all the resource files every time?
any update on this? I tried naming all of my Variants what I wanted their name to export as, which worked until I needed to adjust something in one of them and now they won’t update in other files, which is kind of the entire point of Variants…
  • March 29, 2023
We are also experiencing the same issue and we hope Figma will address this problem soon.
+1 on this issue. It’s a hassle for devs to have to rename the file the name of the component should be included in the exported file name as well.
Deanna_Liceaga
+100 This is a huge issue for creating libraries. Figma please fix this!
Marijn
  • 11 replies
  • September 6, 2023
Same here, every time renaming filenames. plz Figma, can you give us some more export control
Given how robust is Figma becoming, this is a big let down when it comes to developer handoff. Figma please give us a workaround natively!
