Components not updating variables?
So I have a published library with a lot of components, one of them I added a variable and published it again, but when I try to use them on my files the change isn’t added. I tried to publish it several times (tried to add simple changes like description, details just to republish that component), but still not working.
As you can see I have 3 variables, they are named right, everything is “published and up to date”.
Also I found that if I copy and paste a child from the library, it paste in a new file as detached instance.
Added more screen captures on another message because the forum isn’t letting me to add more than one :roll_eyes:
Captura2
@Giselle1 Have you:
  1. Made sure you updated the file you’re working with the latest library update?
  2. There’s no conflict in the original component that’s preventing it from being published?
What do you mean with the “latest library update?” i am not using branches and when i publish the library the updates should automatically ask if i want to update the components, it ask it to do, but they still working wrong, i have also another component that is asking me to update with an old variable that is deprecated and also i erased it. It was working OK when i did the changes, and i been having this weird problem since yesterday.
2 - No conflicts.
Here is another example of the library updating wrong or with an “old version” of it:
The update takes an old version of the component:
imagen_2023-04-04_135509665
The actual component (PUBLISHED AND UP TO DATE)
