I have created a badge inside Figma, and it consists of two elements. The background element is positioned at x:0, y:0, and the foreground element is centrally positioned in respect to the foreground element. Both elements are using integer values for positioning. When I go to the export menu I get the following error messages: Origin not aligned to pixels. Origin snapped to (-5, -16). Dimensions may expand by a pixel. I get those messages regardless whether I'm exporting as PNG or SVG. When I export the work as a PNG everything from Figma gets preserved on that PNG image, but the problem starts s when I export the work as an SVG. When I do export it as an SVG file and I open it in Inkscape or I use it as a component on the website, it gets messed up. The gradient from the badge does not get preserved, the edges become rough, and it doesn’t look like an SVG element but rather as a low quality jpeg file. Then I have created a completely new file in Figma and draw a triangle shape inside
I’m feeling like an idiot. I’m on a professional plan, but I can’t find any invoices in my email and I can’t find anyplace in the Figma site to download previous invoices. This should be easy…been looking for 15 minutes and can’t find anything.
I have found out that figma allows you to add links to text in the form of “mailto:example@example.com”, which allows to add a link to email addresses. However, when I try to input a link in the form of “tel:1234567890” it fails and the “Invalid link” notification comes up. I believe that this is not the indeded behaviour of the feature and it should allow users to input any kind of urls, not just web and email urls.
I feel like I have JUST gotten comfortable with the new placements in the right control panel. I went to update this morning and now padding and gap controls, something I use constantly, are nowhere to be found. I’m sure they’re somewhere, but why aren’t they in the place that they used to be? This is so so so frustrating.
New here so this might be a silly question. I’m trying to make a multi page app using figma make. After creating the first page, I can’t seem to find a way to move on to another page. Is this possible or do I have to create each one separately. Any ideas on ways of doing this?
In the new Glass effect there are two ways to change the light‑angle: Using the interactive control with visualization. Entering a value into the text input field. When you adjust the angle via the text field and press Ctrl + Z, the change is undone as expected. However, if you rotate the interactive control and then press Ctrl + Z, Figma instead undoes the last unrelated action (e.g. the preceding tool change), skipping over your angle adjustment entirely. Consistently reproducible? Yes, every time. Any error messages? No error messages; undo simply targets the wrong stack entry. reproduction steps: 1. Select a object with the Glass effect applied. 2. In the right‑hand panel, click the control “angle” control and drag to change the light angle. 3. Immediately press Ctrl + Z. 4. Observe that Figma undoes the previous unrelated action, not the angle change. 5. (Contrast) Repeat step 2 by typing a new angle value into the text field; pressing Ctrl + Z correctly reverts that change. Bug i
testing
This occurs when I have an instance in my clipboard and I attempt to paste-to-replace an instance inside another instance. It’d be great to be able to use the paste-to-replace keyboard shortcut to swap instances, rather than going through the hassle of selecting the nested instance and swapping it for another through the properties panel.
Hi my fellow friends, I hope you guys are doing well! I'm currently seeing the "Education Plan" label associated with my account, and I'd like to remove it. I believe it's connected to a team I was part of or created while on the Education plan. However, I no longer need access to this plan and would prefer not to have the Education label shown. Could you guys help me assisting me in removing or downgrading the Education plan associated with my account to basic plan ie starter plan
I’m having trouble finding the Auto Layout configuration after updating to the latest version of the Figma Desktop app (I’m using a Mac). It’s no longer showing up in the usual spot on the right-hand panel. Below a screenshot showing two rectangles that are already using Auto Layout, but I can’t seem to find the configuration settings for it.
We (as a team) had created a full page and from one to another it has disappear. We can’t recover it even going back to the version history. Has anyone gone through similar experience?
I have been facing this issue continuously for the last 4-5 days & it’s getting frustrating. When is Figma Team resolving this? __/\__
Since the liquid glass update, when I click on typography settings, they don’t open.
I was approved on student plan with my personal email while working with one school but I switched to other school where I want to be the educator. Since I was already approved on student plan I don't have option to change to educator's plan. I contacted Figma's support but as I see they sent bot reply which isn't connected to my case and repeats what I have already read in the internet. Can anybody help me figure out how to approach this case?
I'm encountering an issue with the Variables API endpoint when attempting to export local variables. The endpoint returns all remote variables from shared files, making it impossible to export only local variables. Current Behavior: The endpoint returns all remote variables from shared files Unable to filter or export only local variables Receiving a 400 error with "Request too large" message Error Response: { "status": 400, "error": true, "message": "Request too large. If applicable, filter by query params." } Technical Details: The error message suggests using query parameters for filtering However, the endpoint documentation doesn't list any available query parameters The endpoint lacks pagination capabilities This limitation makes the endpoint essentially unusable for files with many variables Expected Behavior: Ability to export only local variables Support for filtering variables (local vs. remote) Pagination support for large variable sets Impact: This issue significantly impact
Find answers, learn more.
