Add support for telephone number links
  • July 15, 2021
  • 44 replies
  • 20210 views
Giorgio_Acquati
I have found out that figma allows you to add links to text in the form of “mailto:example@example.com”, which allows to add a link to email addresses. However, when I try to input a link in the form of “tel:1234567890” it fails and the “Invalid link” notification comes up. I believe that this is not the indeded behaviour of the feature and it should allow users to input any kind of urls, not just web and email urls.
Deniz_Kerim
Hard agree. For now though does anybody know of a plugin that can do this?
Daniel_White
Come across the same issue and was hoping there’d be a simple solution… I’m formatting a CV in Figma (might be an usual choice I know, but want to practise using it!)
Managed to link the email easily with the standard ‘mailto:’ why won’t ‘tel:’ work?!
PJ_Mullen1
  • August 19, 2021
One can easily add links to web pages in text fields and they even export correctly to pdf (which is great). However, many of the Figma files I make to export to PDF include phone and text numbers. I would like to make these clickable links much like they are on webpages.
Currently in Figma, When I enter “tel:” or “sms:” as the protocol, it shows the message “Invalid link”. A lot of these PDFs are sent via email and are opened on mobile phones/Macs so it is a common practice for me to make phone numbers clickable.
Right now I have to use Acrobat 🤢 to linkify the phone numbers, and the way Figma currently exports PDFs is not very Acrobat edit friendly.
It would be a great addition to Figma to allow using protocols in URLs other than just “http:”/“https:”/“mailto:”. And, though I might not a use them atm, I can see others wanting to use custom, specific protocols for apps.
  • September 18, 2021
Artak_Gaboyan
Same request.
That feature is really missing.
+1
…just wasted a good 20 minutes trying to figure out how to set up a link to no avail when I finally notices the error message that shows at the bottom of my screen for a split second “invalid link” … more like “unsupported link” because it’s just as valid as mailto: and is very missing. Please support this protocol.
InobMabiki4
+1, really missing the support for tel links
InobMabiki4
I’m preparing a PDF CV in Figma and I want to put an active link with my phone number as a contact method. After some tinkering I’ve found a workaround described below.
Where +XXXXXXXXXXX is the phone number:
  1. Create a mailto:+XXXXXXXXXXX@tel link instead of a tel:+XXXXXXXXXXX link
  2. Once finished, export and save the PDF file
  3. Open the file in a hex editor
  4. Search for XXXXXXXXXXX and find a line like /URI (mailto\072\0537XXXXXXXXXXX\100tel)
  5. In that line, remove \100tel and replace mailto with tel
  6. Save the edited file
  7. Open it on a smartphone and tap the link to test it
keep commenting until it’s a feature 🙂
tammy.storch
Our team is literally just meeting now and discussing the need for tel link feature… sorely needed! Cmon let’s do it!
Florian_LEFEBVRE
I’m also interested in this.
Chase_Stubblefield
I’ll also add that there is a bomb plugin called Emailify which revolutionizes the way emails are created, and this is a huge fail to not support tel links…
Maryjose_Cobos
Honestly yes, I just discovered that you can’t do this on Figma and I missed it so much. Definitely, something interesting and useful to add on.
magali_90
  • August 21, 2022
Yes, please. +1
Matej_Hlavacek
  • September 1, 2022
just do it
Patrick_Pammer
we would need this feature as well to insert tel: Links
Killian_Dal-Cin
Will also really need it too 🙂
Cheyne_Kohl
Desperately hoping for this feature too!
Derek_von_Schulz
Agreed, let’s get it added!
Lucas_Sebastiao_Lima
We all need this feature!
Aaron_Ellis
I’m kind of shocked this still isn’t possible. mailto has been there for a while… why only support for one type of link?
dimaakoot97
After the actions performed, the PDF file does not open 😦
dennsi
  • Active Member
  • October 21, 2022
+1 Yes please add support for tel URLs…
Figma seems to automatically attach “http://” to it resultung in invalid links.
Elena41
  • November 3, 2022
+1 Need this feature badly =^_^=
Edison_Costa
For me works like a charm. Thank you so much, @InobMabiki4
