Cannot find name 'document' error when building plugin UI with Webpack
aashreys
Hi Figma,
I’m following the instructions to set up Webpack for a Figma plugin I’m working on as per these https://www.figma.com/plugin-docs/bundling-webpack/ instructions.
However, after setting everything up, I’m running into the following errors while building the plugin
ERROR in /Users/aashreys/Workspace/figma/figma-controller-prototyper/src/ui.ts
3:0-8
[tsl] ERROR in /Users/aashreys/Workspace/figma/figma-controller-prototyper/src/ui.ts(3,1)
      TS2584: Cannot find name 'document'. Do you need to change your target library? Try changing the 'lib' compiler option to include 'dom'.
4:18-26
[tsl] ERROR in /Users/aashreys/Workspace/figma/figma-controller-prototyper/src/ui.ts(4,19)
4:54-70
[tsl] ERROR in /Users/aashreys/Workspace/figma/figma-controller-prototyper/src/ui.ts(4,55)
      TS2304: Cannot find name 'HTMLInputElement'.
6:2-8
[tsl] ERROR in /Users/aashreys/Workspace/figma/figma-controller-prototyper/src/ui.ts(6,3)
      TS2552: Cannot find name 'parent'. Did you mean 'parseInt'?
9:0-8
[tsl] ERROR in /Users/aashreys/Workspace/figma/figma-controller-prototyper/src/ui.ts(9,1)
10:2-8
[tsl] ERROR in /Users/aashreys/Workspace/figma/figma-controller-prototyper/src/ui.ts(10,3)
6 errors have detailed information that is not shown.
Use 'stats.errorDetails: true' resp. '--stats-error-details' to show it.
webpack 5.52.1 compiled with 6 errors in 220 ms
After searching the internet it seems like the solution to the problem is to compile TS against the ES6 standard. But being very new to web dev, I’m not sure what this means or how I should go about doing it.
Can someone help? TIA 🙂
Best answer by Gleb
Check out this project, I use a slightly modified config from here for Rollup: GitHub - thomas-lowry/figsvelte: A boilerplate for creating Figma plugins with Svelte
Regarding esbuild, I haven’t tried it yet but check out the following resources:
  • 4707 replies
  • September 13, 2021
There is a solution described in the error message you sent:
In the tsconfig.json file or in the TS compiler options passed to webpack, add "dom" to the array called "lib". https://www.typescriptlang.org/tsconfig/lib.html
aashreys
  • 5 replies
  • September 14, 2021
Ah I didn’t know where to add it earlier, but that fixed the error I mentioned. I now get a new Webpack error that seems to be coming from HtmlWebpackInlineSourcePlugin
aashreys@Aashreys-Mac-mini figma-controller-prototyper % npx webpack --mode=development --watch
asset ui.js 49.4 KiB [compared for emit] (name: ui)
asset code.js 36.6 KiB [compared for emit] (name: code)
asset ui.html 909 bytes [compared for emit]
runtime modules 937 bytes 4 modules
cacheable modules 26.6 KiB
  modules by path ./node_modules/ 8.86 KiB
    modules by path ./node_modules/style-loader/dist/runtime/*.js 5.02 KiB 6 modules
    modules by path ./node_modules/css-loader/dist/runtime/*.js 3.85 KiB
      ./node_modules/css-loader/dist/runtime/cssWithMappingToString.js 2.28 KiB [built] [code generated]
      ./node_modules/css-loader/dist/runtime/api.js 1.57 KiB [built] [code generated]
  modules by path ./src/ 17.7 KiB
    modules by path ./src/*.ts 14.4 KiB
      ./src/ui.ts 384 bytes [built] [code generated]
      ./src/code.ts 14 KiB [built] [code generated]
    modules by path ./src/*.css 3.32 KiB
      ./src/ui.css 1.11 KiB [built] [code generated]
      ./node_modules/css-loader/dist/cjs.js!./src/ui.css 2.22 KiB [built] [code generated]
ERROR in   TypeError: Cannot read property 'source' of undefined
  - index.js:53 HtmlWebpackInlineSourcePlugin.resolveSourceMaps
    [figma-controller-prototyper]/[html-webpack-inline-source-plugin]/index.js:53:22
  - index.js:118 HtmlWebpackInlineSourcePlugin.processTag
    [figma-controller-prototyper]/[html-webpack-inline-source-plugin]/index.js:118:30
  - index.js:42
    [figma-controller-prototyper]/[html-webpack-inline-source-plugin]/index.js:42:24
  - Array.forEach
  - index.js:41 HtmlWebpackInlineSourcePlugin.processTags
    [figma-controller-prototyper]/[html-webpack-inline-source-plugin]/index.js:41:23
  - index.js:25
    [figma-controller-prototyper]/[html-webpack-inline-source-plugin]/index.js:25:27
  - new Promise
  - Hook.js:22 Hook.PROMISE_DELEGATE [as _promise]
    [figma-controller-prototyper]/[tapable]/lib/Hook.js:22:14
webpack 5.52.1 compiled with 1 error in 2179 ms
  • 4707 replies
Not sure what this means, I don’t use webpack myself.
aashreys
  • 5 replies
Gotcha, lemme see if I can get this to compile without Webpack. I don’t have too many files in my plugin yet.
  • 4707 replies
Just to clarify, I don’t use Webpack but I do use Rollup, which is essentially the same thing with different configuration and extensions. Also thinking of switching to esbuild.
If you wanna compile to a single file with just the TypeScript compiler, it’s possible: https://www.typescriptlang.org/tsconfig/#outFile, but only if you are not using any libraries and only want to compile the files that you have created. I don’t think TS can compile all imported libraries too.
aashreys
  • 5 replies
Gotcha. I do have a few files I want to bundle, so something simple and fast like esbuild will be perfect. I’m looking at it now. Thanks so much!
aashreys
  • 5 replies
@Gleb can you share how you are using rollup to create a single UI HTML file with css and js inline? I tried using esbuild, but there seems to be no plugin that can achieve this. Now I’m left with Rollup as my only option.
  • 4707 replies
DrunkOldDog
For the people that are following the official Figma instructions and still wants to use webpack, you have to add the following configurations in the webpack.config.js file:
  output: {
    filename: "[name].js",
    publicPath: "/",
    path: path.resolve(__dirname, "dist"), // Compile into a folder called "dist"
  // Tells Webpack to generate "ui.html" and to inline "ui.ts" into it
  plugins: [
    new HtmlWebpackPlugin({
      template: "./src/ui.html",
      filename: "ui.html",
      inlineSource: ".(js)$",
      chunks: ["ui"],
      inject: "body",
    new HtmlWebpackInlineSourcePlugin(HtmlWebpackPlugin),
The publicPath: “/” is for fixing the error of ‘source’ as undefined. Additionally, I had to add the inject: “body” because the HtmlWebpackInlineSourcePlugin was injecting the scripts before the html was rendered. With this property, the scripts are injected in the end of the body tag.
Bahtiyar_Ahmidi
This helped me a lot! I think Figma official documentation has to be updated.
Bahtiyar_Ahmidi
But another problem arose, Webpack not hot loading when I save the file, I had to restart the start script every time!
Bahtiyar_Ahmidi
Turns out the reason for this is html-webpak-webpack turns on the caching by default.
Learn more
To fix this, just add cache: false to the arguments of new HtmlWebpackPlugin().
Dmitri_Bilyk
Note: publicPath: “/” now needs to be “/dist” based on the new tutuorial (at least that’s what finally made it work for me 🙂 )
