Auto Layout behavior in component instances
Keegan_Foster
I have a dropdown component that has 4 selectable options inside an auto-layout.
If I’m in a component instance and I want to add a 5th selectable option, I select an option [item] and duplicate it.
Instead of sticking in the component and it’s auto-layout, the option is sent outside of the component completely.
Is this behavior intentional? I would assume in an instance of a component I can still add items to an auto layout.
If this behavior is intended, how should a “list” component - where more options may need to be added - be handled?
  • 4870 replies
  • June 28, 2022
You cannot add new elements to a component instance. Therefore, the forum has the following requests:
Currently you can create a component with the maximum number of items and then hide the unused ones.
  • July 28, 2022
