Apply variable for x/y coordinates
Stephan1
Hello.
I guess variables will be possible for many more settings. I just worked on a prototype where applying this on the x/y coordinates would have saved me many variants. Looking forward to this
Pavel_Kiselev
Have you tried auto layout frame? Setting top and left padding should do the trick for you, hence they are subject to change via variables
Stephan1
  • 4 replies
  • July 2, 2023
Hey Pavel, thx. I haven’t as I ended up with a setup using absolute position. I will try it out with a variabel for padding and auto-layout. That indeed should work
IraX
  • 145 replies
  • July 2, 2023
That’s what I was doing for the “weird” positioning:
Jorge_Montero_GFT
do you found any solution? i want to use variables on X coordinate to animate a KM Slider, with somethin like "on drag → “if #KM = XXX” “X coordinate=XXX”
Jorge_Montero_GFT
  • October 31, 2023
