Absolute positioned object with constraints not scaling with Auto Layout
ASMarly
The title says it all. When I scale a frame with Auto Layout and I have something with a constraint, it won’t move or scale, and just stay there.
  • 4873 replies
  • November 2, 2022
Could you demonstrate it on a video or send a link to a file?
ASMarly
  • 6 replies
  • November 4, 2022
Sorry for being late but this is the file.
  • 4873 replies
  • November 4, 2022
Thanks for the link to the file.
So, I’ll start with the fact that there is no interactive components bug here, because there are no interactive components in the file.
Also, since the parent frame has a fixed width and height, and the text layer is set to hug, this is expected behavior. If you don’t want the text to go beyond the auto layout, then set it to “Fill container” instead of “Hug content”.
But the most important question is: why are you using an object with an absolute position?
ASMarly
  • 6 replies
  • November 4, 2022
the parent frame is supposed to be a hug width and height but i forgot to change it when linking, also i couldn’t find the right spot to put it in.
the reason im using an object with an absolute position is so text stays in front, because i changed it to show off what was happening.
  • 4873 replies
  • November 4, 2022
Could you show a screenshot of what it should look like? I still don’t understand what result you expect.
ASMarly
  • 6 replies
  • November 4, 2022
ill show with another file using another thingy or whatever i should say. its sort of overflowing. heres a comparison of what is correct and what isn’t
  • 4873 replies
  • November 4, 2022
Set “Hug content” for the auto layout that contains the text and “Hug content” for the text layer. Or, if your object is fixed width, then set “Fill container” for the text layer.
ASMarly
  • 6 replies
  • November 4, 2022
i’ve done exactly that. this is the file tree thing:
ASMarly
  • 6 replies
  • November 4, 2022
maybe you could try making your own speech bubble like what im doing?
  • 4873 replies
  • November 4, 2022
Ah, you’re using Union. Okay, look at the file:
Figma – 4 Nov 22
ASMarly
  • 6 replies
  • November 4, 2022
thank you for helping me! i never would have figured this out.
  • December 4, 2022
