LAUNCHED: True Aspect Ratio Lock
Mr.Biscuit
Can we get a true aspect ratio lock when the ‘Constrain Proportions’ is on?WX20210123-114719@2x A true aspect ratio lock means two things:
  1. When dragging on a node with ‘constrain proportions’, its width and height always stay in their original ratio no matter which direction you drag it.
  2. When resizing on the parent of a node with ‘constrain proportions’ that happens to be constrainedWX20210123-112532@2x, the node takes on the smallest of its supposed width and height, and calculates its ratio accordingly.
This would be so very helpful to polygon shapes that want to stay in that shape. Consider a spider chart. When you resize its parent, you don’t want the ‘spider net’ to squish squash; neither will you want a doughnut to turn into an oval.
*Resizing of the node’s parent layer is inevitable if you need responsive designs.
Pinned reply
February 7, 2025
Hey everyone, thanks for your patience! It’s fully rolled out now!
You can now lock the aspect ratio of almost any object in Figma – including frames, shapes, images, videos, vectors, and text – so that the proportions of that object are respected as you scale the object or its parent container.
 More info in the release notes here.
Ari
  • January 26, 2021
I feel like this is a must-have feature as it has been quite an issue in my project for me… especially being somewhat new to figma.
I’ve seen workarounds with adding a line at an angle using responsive layout, but it’s just a workaround and has quite a few limits.
Mr.Biscuit
  • 109 replies
  • January 26, 2021
Exacto!
Marcelo_Davanzo
People work with images and this is super necessary in those cases. If I set my image container to a 16:9 aspect ratio when it’s 160x90px, I’d obviously expect it to be 320x180px when I scale it to twice the width, not 320x90px.
Chris_Doner
A big +1 from our team as well.
Asaad_Mahmood
Huge Huge +1
Valeo
  • March 20, 2021
Aspect ratio lock needed in auto layout and constraints, so block does not change proportions during scaling.
There is nothing to add here…
Baffour
  • 53 replies
  • May 6, 2021
Agreed, have this problem with SVGs in an auto layout. Sometimes have to resort to images, which makes hand off not as easy because devs should be using the SVG in code. Also have certain UI elements like charts I want to show in designs and the only way for them not to break is to copy as images which then means you lose the ability to inspect etc. Leads to a lot of busy work to find other means of communicating to engineers!
adamfishercox
Incredibly important feature that’s missing! Are there any plans to add this?
Adam
  • 47 replies
  • May 18, 2021
Right now, it is not possible to make a square frame that resizes via parent frame. It always distorts into a rectangle.
Even with “constrain proportions” toggle selected, it does not constrain the proportions. To make matters even worse, the toggle only “works” when changing the numeric fields of height/width, which then breaks snap-to-pixel-grid. But then when holding shift and dragging a corner of the frame, it constrains proportions and maintains the snap-to-pixel grid functionality.
I believe a toggle/option in the constraints panel (example: width = fill container, height = maintain proportions) could do the trick.
Matt
  • June 14, 2021
This is critical for responsive components and is a frequent barrier for the team, is this on the roadmap @Figma ?
Matus_Hatala
It’d be great if there was a toggle I could check that would keep the same aspect ratio for a component inside auto layout. Meaning if the width changes, so does the height while keeping the same aspect ratio.
Mr.Biscuit
  • 109 replies
  • June 21, 2021
Hi everyone, I’ve made a tutorial on how to achieve true aspect lock with just 1 AL Frame, I discovered it two months back and have put it to the test, it works perfectly, 100% bug-free, → Check it out
Constantine_Zuev
It is not “true aspect” lock. I see it still crops or lets background to be seen at some aspect ratios. Am I doing it wrong? Also almost always brakes if you make it a component.
Mr.Biscuit
  • 109 replies
  • June 25, 2021
Okay, It is the closest to true aspect lock Figma lets you achieve, let’s put it that way, and for your second question, I haven’t shared publicly how this works on components, but it is quite easy and works the same way, it just needs one bit of additional work. But let me provide some context:
Olivier_Bubendorff
Totally agree! 👍
wgo
  • 41 replies
  • December 17, 2021
Yes, please Figma-Team, can we have the aspect-ratio-lock behave like the OP suggested? As much as I love all the smart little details in Figma, this current behavior is an absolute strange oddity within all design software out there. Probably every other app does this right(er) than Figma.
When the lock is closed, the aspect ratio of an element should stay the same, no matter from which side or how it is scaled. When in an AL container and set to “Fill container”, the last chosen setting (horizontal or vertical) overrules any other setting. But elements should not be distorted when the lock is closed.
This seems so basic and after 1½ years of using Figma I still can’t figure out why you did it the way it is. And this can’t be that hard to implement, right? So Fimga-Team members, if you are reading this, please reconsider this thing and make it one of the smart details. I even give you all my thank-yous in advance… 😎
Dario_Stefanutto
This is a missing feature to make truly responsive designs. A lot of websites and apps have a page with a grid of thumbnails with fixed aspect ratio. Currently there is no way to have these thumbnails keep their aspect ratio with auto layout, so the only way to do so is by using some tricks like this: https://www.figma.com/community/file/873125264217713781/Fixed-aspect-ratio-in-Figma-Auto-Layout
Oliver_Sommermann
Yes please. It just seems like it’s doing nothing right now. Would help immensely in doing responsive UI.
wgo
  • 41 replies
  • March 30, 2022
Problem is, 136 votes might not be enough for them to take action… 😢
Is everybody else happy with the current behaviour then?
Mike_Heighway
This seems to be a pretty important feature.
Ligia_Muraro
To me it’s happening the exact opposite. I want to deform the image and I can’t.
Neeraj_Mohan
We need this feature! Commenting here to upvote the topic so as to make it a feature. Thank you Adam!
Bryan6
  • June 16, 2022
I’ve spent hours trying to figure out how to make an icon scale proportionally within a frame. Not sure if I should be …
  1. Relieved: I wasn’t stupidly overlooking this feature … since it doesn’t exist in Figma.
  2. Grateful: I could’ve spent hours more, looking for a feature that doesn’t exist in Figma.
  3. Concerned: that folks have, for a year and a half, been asking for a “pretty important” feature that still doesn’t exist in Figma.
I’ve worked with Sketch and XD and am a recent convert to Figma. Love it! But I’m surprised that the aspect lock feature is missing. Would be great to see that sometime soon. Thanks!
Mariano_Pelaez
The big problem here is that when we have a component with autolayout variables and the variants change the size, the content does not fit proportionally because that is only done manually. There has to be a way where the scale is proportional for the variants to work and adapt to the part that contains them
Admin7
  • August 11, 2022
Just reiterating here, odd that it doesn’t provide this when scaling is such a common task.
I find it difficult to be perfectly precise and then the image seems just a little off most times
+1 VOTE
