Helge_Wadewitz
Jun 13, 2022 1:20 PM UTC
SOLVED - Preserve Scroll Position (please roll back the feature)
Hey, i face a bug since there has been an update on the preserve scroll position behavior yesterday. By now the former preserve scroll position, which i had to set manually before is now set as default. So i don’t need to tick the box anymore.
But, in my protoype, although i expect now that the scroll position is preserved by default, it is not working correctly. From screen to screen my prototype is jumping to the top. I need to ship my proto today to the client and this is super annoying.
Anyone faces the same issue since yesterday? @Figma_Support can you roll back the feature? 🙏
Milos_Novakovic
May 31, 2023 8:33 AM UTC
Seems that solution is that frames must have same name, and then by default scroll position will be reserved.
Gareth_Davies
May 31, 2023 10:12 AM UTC
Yup that works for me too, but I agree that it’s not very intuitive though.
May 31, 2023 10:36 AM UTC
The same naming niether works for me.
May 31, 2023 11:50 AM UTC
Thanks for suggesting this fix, that seems to be helping for now. But I would expect the preserve scroll option to be brought back as an option, this took a few hours to figure out!
Jim_Muirhead2
May 31, 2023 1:35 PM UTC
I have my frames/objects named the same between top-level frames, and they show up as the same object when I select an object in one of the top-level frames (indicated by purple outline on object in each top-level frame), but the scroll position isn’t being preserved properly when navigating back and forth - jumps several pixels in each direction. This worked much better in previous state management. Hope they fix this soon.
Jim_Muirhead2
May 31, 2023 1:42 PM UTC
It is totally untenable/unworkable to have to name top-level frames identically to get prototyping working correctly. I shouldn’t have to conform my system for naming top-level frames to get prototyping to work correctly. This was NOT an issue or requirement in previous state management. And even when I do name them the same, the scroll position still jumps several pixels between frames.
Jim_Muirhead2
May 31, 2023 1:54 PM UTC
Got to admit that the “name / subname” fixes things. So in a particular flow I just adjust name to “1 / current frame name” to keep things simple and not having to throw away my naming system.
May 31, 2023 2:52 PM UTC
Having the same issues as everyone else mentioned in this thread and prototype looks flawed. I need this to present to important clients but not in its current state. It looks unprofessional and clunky in and @Figma_Support needs to help sort this for everyone as soon as they are able?
May 31, 2023 4:53 PM UTC
Hi all,
Thanks for reaching out about this and our apologies for the disruption!
It sounds like you’ve run into some issues related to the limitations with the new State management for prototypes update, and for most users this is because the layers do not share matching names. In order for top level frames to share scroll state, they need to have matching names according to this rule.
=> Tips: for the frame naming, you can have different names but need to be identical before the ‘/’. (cf. screenshot)
If you are still running into issues after trying this, please reach out our technical team here.
Please also make sure to use your Figma account email, including a link to the file, and share it with support-share@figma.com as an editor on this file so the team can take a closer look.
Thank you!
May 31, 2023 6:54 PM UTC
I added them to my file, in there you can see on the “C/Services Active” flow the frames are named the same but will still have the scrolling position reset in the prototype 😦
