Daniil2
Jun 9, 2021 2:07 PM UTC
Plugin for viewers
Hello!
I ran into a problem that I could not find in your help. There is a Status Annotation plugin, it is very well for work’s control. I make a design for a client, and he’s could control the process with this plugin. But he’s a manager, not a designer. The client usually acts as a viewer, not an editor. This is done so that he cannot spoil anything in the design. But the viewers doesn’t have access to the plugin. Plugins can only be used by editors.
Could you make plugins available for viewers? It will be so usefull.
Thanks
danhendersonede
Mar 16, 2022 4:50 AM UTC
I have a plugin that turns spec layer info on and off which is useful for developers who want to see the design with and without it but not possible without access to this plugin 😑
I’m in a similar position, using a plugin to toggle layer visibility to show and hide specs to have one design source of truth. Viewers need to be able to toggle layer visibility.
Daniel_Llach
Apr 1, 2022 2:32 AM UTC
I need to create a plugin that works only in view mode!!! please allow us to do this 👏
Lucas_Pizzagalli
Apr 5, 2022 2:00 PM UTC
This would be great!
Jason_Grant
Apr 24, 2022 1:16 PM UTC
I can’t believe this is not an option already. I want to have a plugin where engineers can see the components used in a frame and code snippets based on our repository.
Kaitlyn_Hova
Apr 25, 2022 11:01 PM UTC
Is there any way to get traction on this? This would be invaluable for designers to effectively communicate with engineers that should only have view access. For example, using the Figma Tokens plugin.
Nico_Csanyi
May 10, 2022 9:59 AM UTC
We are also looking for a “viewer role” search function on text. Plugins are not available for viewers… Any update?
We are finally writing guidines, but without ctrl+f, its annoying for our readers.
Katie8
Jun 9, 2022 7:25 PM UTC
Same here! I would love to use a plugin like Frontitude to push text changes in view-only mode. This feature would help so much! I’m a product designer looking for a way where other teams like sales/delivery can easily edit texts in Figma screens and add those to their client presentations.
Yichen_Liu
Jun 14, 2022 10:27 AM UTC
Both developers and designers need search some text or color in a design file. I believe Figma own implementation is better than plugins.
Caroline_Magalhaes_dos_Santos
Jun 23, 2022 8:06 AM UTC
Hi Figma team,
Any update on this matter? it seems a common need to have plugins available for viewers. It would be very appreciated to have an answer.
Baffour
Jun 28, 2022 4:51 PM UTC
Title says it all really, as it stands you need to have edit access to a file to run plugins. However there are tons of useful plugins like Contrast, which don’t modify anything in the user’s files, and would be useful to users with read-only access.
With widgets having just been introduce in Figma, I’ve come across the Navigate widget which helps users move around your file. This would also be useful to read-only users. And in this case the widget developer would presumably want to make it so only editors can set up the navigation, but anyone can click the button to be taken to the corresponding section of the file. In fact it’s likely to be more useful for stakeholders who are a bit less familiar with the file, who you might not want to give edit access in the first place.
