Daniil2
June 9, 2021
Plugin for viewers
  • June 9, 2021
  • 79 replies
  • 14022 views
Hello!
I ran into a problem that I could not find in your help. There is a Status Annotation plugin, it is very well for work’s control. I make a design for a client, and he’s could control the process with this plugin. But he’s a manager, not a designer. The client usually acts as a viewer, not an editor. This is done so that he cannot spoil anything in the design. But the viewers doesn’t have access to the plugin. Plugins can only be used by editors.
Could you make plugins available for viewers? It will be so usefull.
Thanks
nbsp
June 25, 2021
Yes, I need use my plugin in view-only mode for my coding needs. It’s not possible, what a shame. 😦
Please add this feature. Plugins that don’t modify document at all can easily run in view-only mode.
jay9
July 6, 2021
+999999999999999999999999999 Agree!!!
also developer same!!!
Matej_Trakal
August 30, 2021
Need export plugins as viewer too. I, as developer need export images in specific format available through plugin, but plugin in not available in View only mode…
Marika
September 1, 2021
Yes, it’s a pity & a headache that us non-editors, cannot even do something as simple as search for text within designs that were shared with us, simply because ‘Find text’ is a plugin & NOT an essential part of the software itself! 😑
Catherine_Nguyen
September 3, 2021
I have a plugin that turns spec layer info on and off which is useful for developers who want to see the design with and without it but not possible without access to this plugin 😑
Ivan_Gruziv
September 13, 2021
You can save a local copy of the layout. And then export it to the fig. Then all plugins are available
Penny_Codes
September 22, 2021
You can duplicate the file to your draft and use it from there
_DZ
October 22, 2021
I need this feature,for my developer to know some design infomation
fernandolins_cs
October 22, 2021
+999999999999! Need developers to be able to access SVG Export plug-ins and Status Annotation plug-ins.
John21
October 28, 2021
Need this feature!! +999999999999999999
