Nested property hidden with multiple selection
Show first post
Ian_Palmgren
  • Active Member
  • 20 replies
  • August 12, 2024
Just replying again to keep this thread alive… 🤞
Utkarsh_Kaushik
+1 need this so muchhhh!!! bumping this.
Kartikay_Sharma1
Need this feature. Would save tons of time!
r_sh
  • Active Member
  • 28 replies
  • September 27, 2024
+1 We are doing bulk edits to a design which uses some checkboxes and toggles, and it’s a huge time sink to have to manually select and edit dozens and dozens of components just because the nested properties cannot be multi-edited
Evgenia2
  • October 4, 2024
Same issue here, would be great not to have to go through all instances or copy-paste the proper one each time…
Calvin_Kuo
  • 10 replies
  • October 8, 2024
Bump.
If performance is a concern, is it possible to mitigate that by making the nested properties visible only if the number of selection is below a limit?
Similar to this auto-spacing function that currently has an upper limit for selection, beyond which it’s not available / disappears.
Kelsey_Smith
+1 This is quite annoying to deal with
Morten_Stig_Christensen
Hello again,
I stumbled upon a weird scenario when setting up the different variants in a design system of a component in an example overview. I use nested components to control the size and potential styling so that you don’t have to create multiple variants with the same structure when all you need are different variant states.
For example, an input field has a label, a field area (where there can be an icon, placeholder, and so on), a help text, and an error text. However, we also need to see the different states of the input field, which means Default, Hover, Disabled, Active, In use, Focused, and potentially, for prototyping, we also need Active Hover and Active Disabled.
All of this takes time to set up, but when I want to create an overview of the different examples and display the prototype effects, I have to manually select them all if I want to change the size from Medium to Large, for example. Because my nested options disappear as soon as I choose them all, duplicate, and wish only to adjust the size.
This is a time-waster, so it would be nice to display them instead of hiding them. Please, please, please show the nested properties as well! I’m begging here!
Best regards,
Morten.
Mads_Emmertsen2
+1 Bumping this to keep it relevant
Avery_Smith
  • 4 replies
  • February 19, 2025
Same issue here. Doing file refactors at the moment, and being able to edit the nested instances of multiple selections of the same component would speed things up considerably!
James Beer
  • March 4, 2025
+1 this is key for working with nested instances. Can’t use it without the ability to edit multiple selections for my use cases (tables).
Dont_Panic
  • 6 replies
  • March 5, 2025
+1 This is must have should be fixed. Otherwise it’s just a partial feature not aligned with actual workflow.
Bjarke
  • March 21, 2025
This has been an issue for 2 years now … do we have any updates on a fix?
Marine4
  • March 21, 2025
+1! work can become quite tedious without this feature! please Figma 🙏
Devon Taylor
I’m sure everyone has the same idea - keeping the thread alive until Figma can make the fix. It’s been over 2 years with this issue. We have multiple clients within our agency firm and deal with both our own internal design system as well as client design systems.
It’s a large pain point for my team and myself to individually select components that share the same nested properties and not have the option to bulk select/use the nested options. Hoping that Figma’s team places this into a sprint for fixing.
Hg_Msnc
  • 8 replies
  • April 9, 2025
same issue here!
Vincent_Faure1
same issue.
Tom Egan
  • May 15, 2025
How is this still an issue 2 years on?
Releasing ‘Sites’ that nobody asked for while ignoring core product deficiencies and user feedback.
Hywel_Jenkins
+1. This would be extremely beneficial, two years with no update on this is baffling.
Bruce_Beh
  • 6 replies
  • June 3, 2025
PLEASE! This would save SO MUCH TIME. I don’t get why its taken so long.
Gabriel_Renderos2
+1, we really need this to be fixed.
Dominic
  • 41 replies
  • June 18, 2025
+1, Not having this is killing me
Din_Ashkenazi
please fix this!! ​@Figma_1 @figma
