Antoine
Oct 20, 2022 1:19 PM UTC
Nested property hidden with multiple selection
Been playing around with the “expose nested properties” feature currently in beta.
One of the great uses of variant properties is the ability to batch edit property values on multiple selected components. That use doesn’t carry over to exposed nested properties (yet I hope).
Demo file to help
When selecting one component instance exposing nested properties, said properties display fine. Add another instance of the same component to your selection (using Shift+Click), and the nested properties outright disappear from the right panel.
I haven’t seen this issue raised elsewhere! Do you experience it too?
    Zohra_Jayaraman1
    Oct 3, 2023 8:28 PM UTC
    Has anyone submitted this as a bug report? I don’t think Figma will read this otherwise.
    Oct 9, 2023 6:00 PM UTC
    Hey All, sorry for the delayed reply!
    We shared this thread with the team to review, and the team confirmed that this is not a bug, but rather a current feature limitation.
    We’ve updated this thread to a feature request for future consideration, but to be transparent, right now, allowing for this ability would cause major performance issues.
    Marijn
    Oct 23, 2023 7:59 PM UTC
    +1 Same struggle here!
    David_Ridilla
    Nov 3, 2023 3:38 PM UTC
    Is anyone aware of any plugins that can provide and relief for this issue? All our content blocks are nested and the point is lost without mass editing.
    Adriana_Mandjarova
    Nov 9, 2023 12:49 PM UTC
    +1 working with calendar components is really difficult.
    Nov 16, 2023 6:45 PM UTC
    Hey All,
    Today we launched Nested component props!
    Now nested component properties are visible in both the component playground and in Dev Mode. Previously, only the parent was visible. Learn more about component properties.
    Zach_Ward2
    Nov 27, 2023 4:12 PM UTC
    While these are helpful for some uses, this doesn’t cover the needs for the original issue/post.
    When selecting multiple components from a single component set, you aren’t able to adjust nested component properties. You have to select them individually to change them in the properties panel.
    Seems like a no brainer to have this as an option. I’m sure it was decided to avoid it due to some architectural issues?
    Papes_Christoph
    Jan 5, 2024 8:31 AM UTC
    Hey @dvaliao. I just tested what you mentioned here: When I expose properties from a nested instance in a component, the nested instance properties show up in design mode, Dev Mode component playground, but not regular Dev Mode when the component gets inspected (as you mentioned). Has this feature been removed again?
    Papes_Christoph
    Jan 5, 2024 8:36 AM UTC
    Hey David, the Selection Variants plugin by @Gleb might help to a certain extend 🙂
    Chris64
    Jan 9, 2024 1:19 PM UTC
    +1 Having complex table components with 20+ rows. Table design without batch editing is no fun. ;(
