Nested property hidden with multiple selection
Show first post
Ian_Palmgren
Just replying again to keep this thread alive… 🤞
Utkarsh_Kaushik
+1 need this so muchhhh!!! bumping this.
Kartikay_Sharma1
Need this feature. Would save tons of time!
r_sh
  • Active Member
  • 25 replies
  • September 27, 2024
+1 We are doing bulk edits to a design which uses some checkboxes and toggles, and it’s a huge time sink to have to manually select and edit dozens and dozens of components just because the nested properties cannot be multi-edited
Evgenia2
  • October 4, 2024
Same issue here, would be great not to have to go through all instances or copy-paste the proper one each time…
Calvin_Kuo
  • 8 replies
  • October 8, 2024
Bump.
If performance is a concern, is it possible to mitigate that by making the nested properties visible only if the number of selection is below a limit?
Similar to this auto-spacing function that currently has an upper limit for selection, beyond which it’s not available / disappears.
Kelsey_Smith
+1 This is quite annoying to deal with
Mads_Emmertsen2
+1 Bumping this to keep it relevant
Avery_Smith
  • 4 replies
  • February 19, 2025
Same issue here. Doing file refactors at the moment, and being able to edit the nested instances of multiple selections of the same component would speed things up considerably!
James Beer
  • March 4, 2025
+1 this is key for working with nested instances. Can’t use it without the ability to edit multiple selections for my use cases (tables).
Dont_Panic
  • 6 replies
  • March 5, 2025
+1 This is must have should be fixed. Otherwise it’s just a partial feature not aligned with actual workflow.
Bjarke
  • March 21, 2025
This has been an issue for 2 years now … do we have any updates on a fix?
Marine4
  • March 21, 2025
+1! work can become quite tedious without this feature! please Figma 🙏
