Cody_Porter
Jan 22, 2021 7:19 PM UTC
LAUNCHED: Min and Max Width for Auto Layout
I would like to add a max-width to a text box while using auto layout to keep the word count per line at a reasonable minimum.
Currently, I have the text element set to “Fill Container” which makes the text respond very nicely to the screen size. But because it is set to “Fill Container”, the text spans the entire width of the element which makes the text lines more difficult for users to read quickly.
If a max-width was set, the component should respond until it reaches the max-width, which would help keep the line length down.
I also feel like there are many other circumstances where max and min-width would be extremely helpful
Anyone else having this issue? Or does anyone have a great fix/hack to get around it?
Looking forward to seeing what you have to say.
Cheers,
tank666
Feb 22, 2021 8:07 AM UTC
For min-width, use the zero-height frame hack. For this frame, specify a fixed width such as 400px and place it in Auto Layout. And for max-width, just expand your Auto Layout horizontally so it becomes fixed in width.
Roberto
Feb 24, 2021 10:47 AM UTC
+1
Jip_Asveld
Mar 22, 2021 4:44 PM UTC
@tank666 how exactly do you do this for mimicking a max-width?
tank666
Mar 22, 2021 7:03 PM UTC
I set the max-width manually in the Auto Layout properties, that is, I change from Hug content to Fixed width. Or, for example, you can add a component variant with a switch (max-width=true/false).
Yes, this is not ideal and I voted to add the min / max-width function, but unfortunately there is no other way to do it. In any case, the limitations should be described in the specification.
Tiffany_Lieu
Apr 5, 2021 8:45 PM UTC
Yah that’s what im doing right now, but i’m hoping they can have an extra setting to set that so we don’t have to make extra variants
Yulia
Apr 7, 2021 8:58 AM UTC
+1
Carsten_Jaksch
Apr 17, 2021 9:35 PM UTC
This is the only feature I am missing.
Rizqi
May 21, 2021 7:05 AM UTC
+1 👍
Phil_Larsen
May 22, 2021 10:22 PM UTC
Would be great to be able to specify the max width of an element on resize. This would be helpful in auto layouts and when creating elements that can adapt to various screen sizes during design testing.
Clement_Bettini
Jun 6, 2021 2:15 PM UTC
+1 👍
