New UI - Scale Properties - Tab Order
  • January 28, 2025
  • 4 replies
  • 90 views
naeim
I use the Scale options a lot and 9 out of 10 times I know exactly what size in width or height I want to scale to. I also use Tabs a lot to navigate through options whenever possible.
In the new UI when I click K and open the Scale options the first focus is on the 1x multiplayer and the Tab goes through the alignment box, it takes 20 tabs to go from the multiplayer 1x option to the Width input.
In the old UI, I click K to open the Scale properties, press Tab once and enter my Width…
I believe that most users will agree that the Width and Height inputs should come next after 1x in the tab order. (I am not even sure what that alignment box is supposed to do exactly , I have never used it.)
Atelier N8
  • April 2, 2025
YES!!!
Please fix this, it’s frustrating for someone so used to press tab keyboard to scale something to a precise px and have to manually select the field.
Minimum impact in usability would be to stick with the previous order on this scale feature
Dmitriy9
  • April 2, 2025
Yes. It definitely needs to be done. My speed of work has dropped significantly. Now I can't enter the exact value by just pressing Tab, I have to use the cursor all the time.
Hugo18
  • 5 replies
  • April 9, 2025
OMG YES please! Put that field order back to how it was, everyone got used to press Tab to resize the width, and now it’s messing up the workflow every single time…
anejlm
  • April 29, 2025
YES. This is such a nuisance.
