Prototype resetting Scroll Position
lizaplastun
The problem is still relevant. Can I find out if there will be a fix?
Continuing the discussion from Prototype resetting Scroll Position even though those settings have not been selected:
Best answer by tank666
Do I understand correctly that the bug occurs when collapsing/expanding chapters? If yes, then this is due to a bug in the smart animation of auto layout frames. There are two solutions here:
  1. Instead of “Smart animate”, use “Instant”.
  2. Wrap your auto layout in a frame of a fixed height (set the height equal to the height of the device), and also change the overflow scrolling behavior (from “No scrolling” to “Vertical”) of this frame.
tank666
Have you followed these Help Center articles?
Figma Learn - Help Center
lizaplastun
Yes, I read these articles. I have a problem with animation in components. When animating simple frames everything is fine. And when using an animated component, everything breaks. I can’t find the reason.
tank666
Could you share a link to the example file?
lizaplastun
Figma – 1 Apr 24
Here’s an example
tank666
lizaplastun
The second option worked! Thank you very much!
Louistdesign
I just watched this video
And you can fix it way more easily by renaming your frame with the same exact name and differentiating them using a “/...” it fixed the issue for me and was a real life saver
