Paul_Lyons
Mar 16, 2021 2:38 PM UTC
Prototype bug - My prototypes flick between random screens when Interactive components are turned on
I have quite a big file with many components in use for table cells, buttons, form elements etc, and have been using Interactive components for link / button hover states, check boxes etc.
My prototypes were working well until the last update. Now during random parts of the flow, my prototype randomly jumps between a series of screens, making the prototype unusable.
I went though all pages & elements, checking I didn’t have any stray ‘hover’ or ‘after delay’ actions in place and they were not any. I did however notice that some flows were fixed, by changing some duplicate frame names I had. The issue would however, pop up elsewhere in the flow and could not be fixed by adding unique frame names.
The only thing that stopped the bug, was when I turned off ‘Interactive components’ for the prototype. The prototype then worked fine after that (minus my micro interactions).
Bit of a strange bug, but thought i’d share for investigation.
Ray_Zaranza
Mar 16, 2021 2:45 PM UTC
I have the same problem! 😭 😭
Only works when disabling interactive components… which sucks because now I have to do the whole prototype again without it.
Liz_Hixon
Mar 16, 2021 3:09 PM UTC
I have this same problem. Often, if I close Figma, then reopen it, the prototype will work properly. But either way, this is a bug that should be resolved.
Paul_Lyons
Mar 16, 2021 3:24 PM UTC
Thanks @Liz_Hixon.
I also tried this too, but without any success. Even tried rebooting my laptop.
As you say, I hope this is something they can fix soon!
Andrew_Chan
Mar 16, 2021 10:45 PM UTC
Hi @Paul_Lyons @Ray_Zaranza @Liz_Hixon - thanks for the bug report! That sounds like a regression - if possible, could you share a file or prototype link with me via DM? You can make sure I have access by inviting me in the sharing settings by email (achan@figma.com).
If you can reproduce the bug, a video recording of it would also be very helpful so we know exactly where to look. Thank you!
Liz_Hixon
Mar 17, 2021 8:00 AM UTC
@Andrew_Chan here’s a video I took the other day. I can’t share the file per NDA, but I hope you’re able to pinpoint the bug. Thanks.
111182
Mar 18, 2021 2:04 PM UTC
The same problem. It just started overnight. Moreover, it looks as if by clicking on the space bar and moving to the next frame. By removing some links, I reduced the number of screens that are involved in the prototype and this affected which frame opens on click
Paul_Lyons
Mar 18, 2021 2:18 PM UTC
Hi @Andrew_Chan ,
I also cannot share the file due to the NDA, but have emailed you a video showing the bug.
If you need anything else, please let me know.
Alessio_Viola
Mar 23, 2021 8:59 AM UTC
Same problem here, lot of links on my prototype randomly sends me to different screens not linked to the pressed component. @Andrew_Chan I’ve sent u an invitation as editor, so u can check the problem. The only page in the file where I used interactive components is the last one named “💡SvaGo”. Thanks for ur support!
Andrew_Chan
Mar 24, 2021 11:53 PM UTC
Quick update: thanks everyone for your patience on this - we pushed a tentative fix for this today. Please let me know if the problem continues to occur.
Paul_Lyons
Mar 25, 2021 10:01 AM UTC
Thanks @Andrew_Chan,
The issues seems to have gone for me right now. I’ll let you know if it re-occurs, but so far all good.
Thank you for looking at this so quickly!
