I can't use variables with Team Libraries
raphadesign
I set up a Team library, but when I want to use it, the variables are not showing up in the variables panel. The Components are still linked to the variables, and they show up when I look in the “Libraries added to this file”. Just not in the Variables panel.
Libraries added to this file. Variables are there
Variable Panel is empty
Everything is published correctly. The variables are not hidden for publishing. Currently waiting for support. Maybe someone has any idea, wheter i set it up incorrectly, or it’s just a bug. Thanks for any help
Best answer by Raphael_M
Yup, it won’t show because they are called local variables for a reason—only variables created on that file, locally.
It should show up in here in the Libraries.
Raphael_M
  • 394 replies
  • May 13, 2025
raphadesign
  • May 14, 2025
Alright, thanks!
Hique_Sui
  • May 15, 2025
Usa o Mod slide ... Acho que não tem mais função a frente ... Enfim boa cotação com a firma.
