Undo function is not working on keyboard or using Edit menu
Show first post
LEESUMIN
  • September 3, 2024
rm -rf “$HOME/Library/Application Support/Figma”
Schweiss_Kelly
This issue doesn’t seem to be solved. This bug is still randomly occurring.
ksn
  • 1679 replies
  • September 18, 2024
hi @Schweiss_Kelly - I will have someone on our support team reach out to you.
At the moment, because this seems so intermittent, we have not been able to replicate this successfully However, I’d like to get you connected to see if there are any possible records/logs that I don’t have visibility into that may help.
You’ll see this come through your email shortly!
ksn
  • 1679 replies
For anyone else that experiences this – please drop a comment here with any details/steps you were doing before the undo feature stopped working.
For example:
  • Created a frame
  • Resized it manually
  • Suddenly, undo no longer works
or even:
  • Created a new frame
  • Resized the frame
  • Changed browser tabs (checked my Gmail)
  • Opened a new browser window
  • Moved back to my Figma tab
  • Undo stopped working.
Those types of things are helpful, because we can see if there’s a trend that may be triggering this. ty everyone for your patience! I will re-title this to reflect that this may still be an issue for some.
Schweiss_Kelly
Thank you so much! Hopefully there is some insight I can offer!
Maurice1
  • September 25, 2024
I am a hardcore keyboard user, this bug is still there, it comes randomly.
Fist time i explore it was few weeks ago. Never happen befor.
One a way to fix it is to complete restart figmaApp.
What a annoying bug guys!!!
Please Guys, dont change permanent Keyboard Shortcuts, that is total annoying too, mabye this is a reason i find the bug cause the old Keyboard Combinations dose not work anymore and i hit a combination that is disabled and create the effect.
Hugo_Mallinger
Hello
I had the same issue and went to help>keyboard shortcut>Layout only to see that Figma somehow selected an incorrect keyboard which was not matching with my laptop keyboard configuration. I changed the value to the detected keyboard and it worked.
Not sure why a random keyboard was selected instead of my actual detected keyboard.
Mark_Steinruck
I’m having this same issue and it came about very suddenly. I’ve cleared the cache multiple times, checked to see if CMD + Z works in Safe Mode on a Mac (it does), and rebooted multiple times. I also checked my keyboards and they match. So according to this thread, it should be working but it’s not.
  • 2544 replies
  • January 16, 2025
Hey ​@Mark_Steinruckthanks for flagging.
Could you submit a bug report detailing the steps that led to this issue? You can do so by following the link: https://help.figma.com/hc/en-us/articles/360041468234-Submit-a-bug-report
Thanks for your patience!
Toku
