Thibaut_netatmo
December 15, 2022
Nested variant instances within a component are reset after the library update?
Hello everyone 🙂
1 year later, I think I’m experiencing exactly the same issues as those mentioned in these topics:
Unfortunately, the solution suggested in the related topics I mentioned above — reload Figma and run “Fix instance overrides” from the Quick Actions — is outdated and no longer exists.
If there a new solution?
if I may summarise the issue:
When we nest a variant instance within a component, use that component in another file and select a different variant value than the one defined by default, then every change related to that component published from the library and updated in the other file will reset the modified variant instance within it.
Here is a video I made to make it as clear as possible ↓
Please let me know if any of you are also affected by this issue.
If my example only shows a reset of the variant name, be aware that this issue affects all possible overrides making it much more annoying with more complex real components!
To me, this looks like a bug that needs to be fixed quickly.
Thanks very much.
Yann_Penhouet
December 15, 2022
Hello,
we have a problem when we modify an instance of a nested component.
Indeed we have a level 1 component with different variants, which we call in a level 2 component.
We call an instance of this level 2 component, we modify for example the fill of one of the layers.
But if we ever change the level 2 (by changing the variant of the level 1 component we call), then the fill resets to match the selected variant.
Is there a solution to this problem?
Thanks
Thibaut_netatmo
January 24, 2023
Hello! I think it’s more or less the same problem I have yes…
I created this topic and made two tickets to the support in the hope that they would fix this bug soon enough.
Gregor_Pichler
March 30, 2023
Did you find a solution for this problem? Facing the exact same issue right now.
Thibaut_netatmo
April 5, 2023
Hello @Gregor_Pichler , no unfortunately I was in discussion with the Support team who were very responsive but after telling me several times that their Engineering team would look into this issue still haven’t got back to me 🙁
Price_Jared
April 19, 2023
I’m having the same issue.
April 20, 2023
I am also having this issue and recently checked with the support team. They say they are aware of the situation, this is a bug, but there is no ETA for any solutions. All we can do is to wait and expect Figma team to resolve this. Until they come up with a solution, we need to fix every single overrides manually after any library updates which means 3+ hours of labor on my side.
Morten_Larsen
Im having the same issue
June 6, 2023
Having the same issue with designers who are using my design system files. This is increasing labor costs. Has there been any resolution on this?
Julianne_Walkiewicz
June 15, 2023
Having the same issue. Any chances to the master component result in overrides for all the custom text in our files and it’s a real problem.
Viorel1
August 11, 2023
Having the same issue, i tried to come up with some work around but unfortunate none, hope to have an answer from Figma Team soon.
