uipastel
Oct 26, 2023 10:39 AM UTC
Missing manifest figma plugins project (update figma)
I’m creating a plugins project, but Figma updates its version, then I update Figma, and all my projects are gone, how do I find this?
GlebSolution
Power Member
Oct 27, 2023 2:46 AM UTC
So you stored the plugin in the Figma app directory? See Yosif’s answer
uipastel
uipastelAuthor
Oct 26, 2023 11:13 AM UTC
@Gleb can you solve about this problem?
Power Member
Oct 26, 2023 12:43 PM UTC
Are you creating your plugins in the Figma’s internal directory, like this person?
If so, you shouldn’t do that. You can put them anywhere you want on your computer.
Oct 26, 2023 4:13 PM UTC
Gonna copy & paste my reply from that thread, hope it helps:
I was able to recover my files, here is the journey I went through in case anyone experiences this:
What I can assume happens is that, when you create a new plugin, it is by default created in a folder that contains the current Figma version. However, as Figma updates, older versions get deleted.
So in other words- if you created your plugin in the folder that contains the current Figma version (which I think is the default option), move it out of there.
Ways you can try to recover your code include:
  1. Github - I had some code in github, but it was ~a week old, which meant I would’ve lost a week of progress.
  2. Windows/Mac/Linux file deletion recovery tools- I am on windows and tried using Windows File Recovery which did not work. I also tried r-undelete, which was able to retrieve one of the deleted files.
  3. Contact Figma support- My plugin is published, and Figma support were able to provide me with the code for the published version of the plugin (thank you Alex!)
So, in short:
  1. If your plugin is in the folder containing the current Figma version, move it out of there ASAP.
  2. Use git every time you make a change.
  3. File recovery tools could work, but there is no guarantee.
  4. If your plugin is published, Figma support can provide you with your published code.
uipastel
uipastelAuthor
Oct 26, 2023 7:23 PM UTC
Can i restore my project for this? Its longest times and hardwork about project
GlebSolution
Power Member
uipastel
uipastelAuthor
Oct 27, 2023 4:05 AM UTC
Ok thanks gleb, solved using EaseUS Data Recovery Wizard.
Nurul Izah
Mar 28, 2025 6:54 PM UTC
Hi, I’m also facing the same problem. My plugin project folder lost because I saved it in the old Figma app directory. I didn't realize it until Figma is updated unintentionally. Could you share how you solved it? I am actually in dire state as the project is my own final year project for my degree.
