Mikael_Cederbom
May 12, 2023 8:01 AM UTC
I can't find 'Memory usage'
Hi, I would like to see memory usage in layers panel. According to the Figma documentation there should be an option called ‘Memory usage’ found in ‘View’.
This option is not visible for me. I find ‘Resource use’ but this does not display the percentage to view how much memory my layers and components are using.
I tried to search (⌘+P) for “memory”, but didn’t get any result either.
I also uninstalled Figma and re-installed, but still no Memory usage option.
What have I missed?
Veniamin_Mylnikov
May 12, 2023 10:48 AM UTC
same problem
Kolberg_Delaney_A
May 12, 2023 7:50 PM UTC
I have the same problem as well and have tried updating desktop app and logging out but I’m still not seeing it!
Veniamin_Mylnikov
May 15, 2023 9:35 AM UTC
@Figma_Support please help
Power Member
May 15, 2023 9:52 AM UTC
Have you tried the old “Resource use” menu item?
Rens1
May 15, 2023 12:40 PM UTC
It seems like ‘Resource use’ has been replaced with ‘Memory Usage’. I got this in an update today. I have to say I prefer the old resource use tab, but was sometimes a bit buggy and inaccurate
Frame 282
AlicePackard
Power Member
May 15, 2023 3:30 PM UTC
wanna connect this thread to a thread I started recently “Resource use is now memory usage (when did that happen?)”
I write about building excellent Figma components on my blog: https://alicepackarddesign.com/blog
Roman_Luks
Feb 13, 2025 9:34 AM UTC
I was in Dev Mode and couldn’t find it. Make sure you’re in the design mode.
