Michelle_Sch
Oct 24, 2022 6:12 PM UTC
Figma keeps saying I'm Offline
Figma keeps saying I’m offline and that it’s not syncing any changes, even when I have very fast and consistent internet connection (Zoom, Slack, CreativeCloud all work fine). And what’s strange is that it’s only for one project at a time. I have four different projects open and the others are syncing fine. And it’s not always the same project that has trouble syncing. Last week it was a different one that wasn’t syncing. Figma is up-to-date as well.
I have had this issue for a week now and it’s incredibly frustrating. Any solutions?
Oct 25, 2022 5:42 AM UTC
Hi there,
Sorry to hear you’re seeing the issue. Could you please check if you can load the changes in another browser? Once you can check the file loads with all changes in the browser or saved a local copy, uploaded and checked it’s complete or copied and pasted the changes to a new file then you can clear your cache (let us know if you need directions for this). This should help with blocked connections on the Desktop app or a specific browser. If you see this in multiple apps/browsers, please don’t clear cache and instead use the (?) to contact our Support team.
The article “Can I work offline with Figma” explains how Figma saves changes made when you are offline.
I hope this helps.
Toku
Penina
Nov 8, 2022 10:53 PM UTC
I’m having this problem, too. I tried opening the file in a different browser and some changes are showing but others are not. What’s especially weird is that some successfully saved changes were made after unsuccessful changes.
Example: I made a copy of a component and detached it. This change carried over to the other browser. I also inserted some images, some by copying and pasting and some by using the insert command. Those are not being saved, from either browser.
I checked with my manager about our license and nothing has been changed there. Other browser pages are opening without problems.
Penina
Nov 9, 2022 12:37 AM UTC
Following up: I thought I would just work on the desktop app in the meantime, but when I try to log in, I get sent back to the browser (expected) which then attempts to download … the login page? … which I can’t open without logging in. I am 100% blocked.
I’ve got a deadline. Moving to different software.
Penina
Nov 25, 2022 11:13 PM UTC
EDIT:
For anyone in a similar situation, we had to resolve this internally with security support personnel. Figma support team helped us confirm and clarify the issue.
In addition to requesting a log file they could review, here’s a redacted version of the support person’s comments:
The errors I’m seeing are indicative of some kind of VPN, firewall of proxy blocking some or all traffic between your system and Figma. [Ask IT admin to take relevant steps]
If there’s no network security in place, can you confirm if you’re seeing this on an alternate computer on the same network if you have one available, and on your usual computer but on an alternate network? This should help us pin down whether this is more likely to be a network or computer specific issue.
I am in a different city, trying from two different browsers, and am continuing to experience these issues. I thought the problem might be due to internet connectivity, but 1,000 miles and another internet provider has not changed things. I realize it’s a U.S. holiday, but it wasn’t when Michelle first raised the issue. Can we get some help, please?
Mar 17, 2023 3:10 PM UTC
@Michelle_Sch, @Penina.
Did you manage to solve this problem?
I had the same problem yesterday, as soon as I try to do something in Figma, I immediately go offline.
Rita6
Mar 24, 2023 12:02 PM UTC
I have the same issue. And the weird thing is that some documents do get updated and other no.
Jon22
Mar 28, 2023 6:54 AM UTC
also having this issue here with random files insisting that I’m offline even though my internet connection is strong, but on top of this, other opened files within the Figma desktop app don’t experience the same issue.
Niki_K
Apr 9, 2023 7:08 PM UTC
Also having the same issue but it’s not consistent across all my projects.
Himanshu5
Apr 17, 2023 8:03 AM UTC
my main working file is not saving and on the other hand, 5 other files are saved and synched properly. If the same file opened on the browser then, it does not show the changes …feeling stuck now 😦
Apr 24, 2023 8:12 AM UTC
This thread was incredibly useful to me. Ive had the same issue and I think its a memory problem and/or a location/VPN issue. My workplace uses a secure network and some systems use VPN, at home my internets so bad I often tether to my phone. Somewhere in that theres a problem.
I followed the above advice to ‘save as Fig’ to my local desktop and that in-itself fixed the issue for me. I opened a web browser version also and everything was there. I suspect that I had outdone Figma memory and I am a tab hoarder, I have 20 files open. Im now going to create a directory to remind me of whats in each file so I can close loads down (a gateway board in Miro with links). I suspect this will massively help.
Once your file is saved down you can also restart Figma with no fears of loosing the work, so Figma might need a restart. For me, merely saving a copy purged the memory for me. Hope this helps someone out there (and maybe Figma too with the context here).
