Component inside component, instance slot
  • August 28, 2024
  • 130 views
Anders_Lund
Hi, I’ve created a component (an dialog) that contains a instance slot section where the designer using this component is able to swap this instance slot to another component. It works, but I with some of the components I get the following error message “components can’t contain instances of themself” a have tried changing the name on the component without any luck, does anyone know how this can be solved or what the issue is?
Ben_Smeets
  • Active Member
  • 40 replies
  • August 28, 2024
Maybe this: The component you are using the instance from, contains the wrapper component most likely. Meaning you will get circular references and an error.
Anders_Lund
I recreated the component with this specific issue and now it works fine, what you say makes sence but it was a bit difficult to solve so I just tried this and it worked fine. Thanks
