Bug - Min Max size (width or height) not showing on component instance
  • August 29, 2024
  • 240 views
Dustin_Hansen2
There seems to be a bug where the Min and Max values do not show up on component instances?
The values do get applied, but they do not show up in the W (width) and H (height) fields, so there is no way to see that’s where the width is coming from, or to clear the min / max when an override is needed.
NOTE: this seems to happen only with nested components. In my example I have a button component, inside a “Button Group (Save or Cancel)” component. An instance of the button shows the Min width, but the button in an instance of the button group does not.
Possibly related: Can’t remove min and max height when the component is nested
Maria C G
  • April 12, 2025
Hi  Dustin,
I have the same problem. Did you find any solution?
Thank you!
Jack Lim
  • April 15, 2025
I’m also having the same problem. Couldn’t fathom the reason.
Erman Tutan
  • April 16, 2025
This happens with nested components. There doesn't seem to be anything to do except wait for an update to cover this issue. Simple but annoying :(
