Elizabeth9
July 24, 2023
Backwards Autolayout and issues with prototypes
  • July 24, 2023
  • 11 replies
  • 1235 views
Has anyone experienced a weird bug where the autolayout align commands appear backwards to the expected result? I.e when I try to left align an autolayout it right aligns it instead. Also having issues with prototype previews within the same file. Wondering if it is a corrupt file or if others are having similar issues.
Best answer by David
@Elizabeth9 are you sure that the Rotation value is set to 0? It’s easy to recreate your scenario when the auto layout has a mirrored rotation set to it? You can still place objects in with the correct orientation, even when a parent is rotated.
Check my demo image here: https://uploadpie.com/KH2uVE
tank666
July 24, 2023
Elizabeth9
July 24, 2023
They are not. It happens even when creating a net-new autolayout within this file.
tank666
July 24, 2023
Could you share a link to this file?
Elizabeth9
July 24, 2023
Unfortunately it is for work and the file contains sensitive info that can’t be shared.
Josh
Former Community Manager
July 24, 2023
Hey @Elizabeth9 are you able to reproduce this in a separate file by chance?
David
DavidAnswer
Elizabeth9
July 25, 2023
You are correct. This was causing the issue with the prototype preview as well. Thank you!
Josh
July 25, 2023
Thanks @David for jumping in to help! @Elizabeth9 glad this was an easy fix for you! 🙂
jasha.aitchison
October 4, 2024
I have the same issue but none of the parents are rotated 🤨
It seems to happen randomly and only in the past few weeks.
Nellya
Power Member
October 4, 2024
Probably it’s not rotated, but flipped
