Nested components/variants bug
skippybooo
Hey guys. I have some problem with nested components/variants. I have structure like this:
– Root component
––– Variant_1
––––– Nested_component_1
––––– Nested_component_2
–– Variant_1
For the third hierarchy level there is no option to convert selected objects to component, neither past/drag one. Actually, even if I detach nested components there is no reverse ability to convert them to components (I don’t know how I made them nested at the beginning (: ). I’ve tried to reset all components - no result, so as wrapping content into frames.
Have any ideas?
Here is link to my design. Subject: component “About_Me”.
Jared_Gibbons
Not sure if this is a bug or general feedback. I have interactive components nested within another interactive component. The nested component doesn’t seem to function as intended. In this example, I have a button nested within a notification component. The button is set up to be interactive, but does not function in prototype.
See the button prototype states in the image below.
Christoph_Foulger
I’m seeing this issue as well. Seemed to start last night/today. Was working yesterday morning. I wonder if it has something to do withe the latest update.
Cesar_Garcia
I’m on the same train, and it started this morning… the fun fact is that I had moments when everything starts working, and then it breaks again. I noticed that also not nested components break as soon as you customize them (ex. text link with a hover interaction, then create an instance (it works) and edit the text string, that breaks the interaction for me.
Tokail
  • 4 replies
  • March 5, 2021
I’m encountering the same issue, one moment it’s working, then it’s broken again.
Ruth
  • March 6, 2021
yep same here. I made a similar post but deleted it because it started working again. low and behold, it’s broken again
Raph
  • 7 replies
  • March 6, 2021
Having the same issue here
Baffour
  • 53 replies
  • March 8, 2021
Having the same issue but don’t even have multiple interactive components. Got a text field that’s interactive + nested in a few non-interactive components, but clicking isn’t doing anything.
Harun_Alikadic1
I have nested components too, but the nested one doesn’t have any interaction, it is just a frame with a text object. So when I try to override the text on the instance level (text appears on hover), the text stays the same as in the original component. Maybe I should have the same child component even in the default state, just hidden?
Sebastien_Wozny
Same thing for me. Until now I had no problem, I even nested some complex components with animations, but now a simple loading bar in another component doesn’t work.
Guus_dos_Santos
Same problem for me as well. I have multiple (child) nested components that are not visible within the (parent) component
tank666
  • 4873 replies
  • August 10, 2022
  1. Create Component 1;
  2. Add an instance of Component 1;
  3. Create Component 2 from an instance of Component 1;
  4. Add an instance of Component 2;
  5. Create Component 3 from an instance of Component 2.
skippybooo
  • 7 replies
  • August 11, 2022
Sorry but I can’t get it. I have to use instances of objects to nest, not objects themselves?
tank666
  • 4873 replies
  • August 11, 2022
A master component cannot contain another master component. In the master component, you can only place an instance of another component and any other objects (text, frame, vector, etc).
skippybooo
  • 7 replies
  • August 12, 2022
Oh, now everything is clear. Thanx a lot!
Lauren4
  • 4 replies
  • August 17, 2022
I’m having this issue too.
RayNi
  • 11 replies
  • August 29, 2022
On 29 August all nested components with interactions don’t work in presentation mode. For example, hovers on buttons don’t work, checkboxes in pop-ups don’t work. I hope this bug will be repared soon.
Macc_cot
  • 4 replies
  • August 29, 2022
Now, as I understand it, everyone has this problem
Eric_Forest
Yep for me its all components, not just nested ones.
RayNi
  • 11 replies
  • August 29, 2022
Andreas_Tabak
Yup same here…I restarted my PC and all interactions stopped to work. I first thought I was nuts, but then checked on the forum and saw that I am not the only one.
RayNi
  • 11 replies
  • August 29, 2022
Yes, it is a crucial issue, I hope Figma will fix this for tomorrow.
Derek_Brumby
Same here. prototypes were all working earlier today but now are not. It seems to be affecting almost all of my prototyped interactions
RayNi
  • 11 replies
  • August 29, 2022
All my files don’t work too. And my work is stuck because it needs nested working iterations to continue.
Selino
  • 4 replies
  • August 29, 2022
Is there any helpful advice for me as I am in the same situation? I have a prototype that was working fine a week ago, and suddenly no nested interactive components work in the same prototype that has not been touched for weeks 🤷‍♂️t4:
  • August 29, 2022
