How to create a repeating diagonal line pattern?
  • January 20, 2022
  • 4 replies
  • 16553 views
Hazel
Hi I am trying to create this effect in Figma, but when I try to make it the diagonal lines do not line up. Can someone please explain how to achieve this? Here is what I get when I do it:
Thanks!
Best answer by tank666
Create a seamless pattern manually or use a plugin to create patterns.
For example:
Figma
This plugin has a pattern similar to yours.
tank666
  • 4871 replies
  • January 20, 2022
You probably need to adjust the Fill Mode. If the “Tile” Fill Mode is not suitable, then you will need to prepare another image in which the tiles are seamless.
Figma Help Center
Hazel
  • 11 replies
  • January 20, 2022
Yes, that is the part I am not sure how to achieve, making the tiles seamless. Would appreciate any help with that.
tank666
  • 4871 replies
  • January 20, 2022
For example:
Figma
  • February 19, 2022
