How do I save text content when creating a nested component?
Ildar_Mahaone
In my project, there is a component that includes an input field and a label (as a text field). The component is used many times for templates and label text is changed.
Now I need to put the label in the component. But this will reset the label text in all consumer files after updating the component from the library. Is there a way to avoid this?
  • May 24, 2021
My plugin Master can do this! Simply select the label, wrap it in a frame (if it’s not wrapped already) and run Master → Create Component from Objects. Master will find all instances of this component in the current file and save overrides in them.
Ildar_Mahaone
This problem occurs with component consumer files. After the file accepts updates from the library.
