Hi, I deleted figma for some reason, and then I want to install it back.
But I install failed 😥
Detail log is here: SquirrelSetup_figmaInstallFailedLog.txt - Google Drive
I tried to follow the steps , but I don’t know where to paste the %APPDATA%\Figma command.
What to do?
Best answer by tank666
Try to uninstall the application like this:
Ok. I find how to fix this problem.
Nedd open soft “command prompt” like administrator
cd "C:\users\kukha\AppData\Local\Figma
where kukha - your user name
del /s /q “Figma”
if they ask something need say “Y”
After all files inside the folder will delete
Now you can install Figma again.
Or like this:
i solved this.
go to :
C:\Users\ your user folder \AppData\Local/figma
and find the _codesign file , then create an text file and zip it with sendto menu then select that _codesign file and hold shift and drag it into zip file , then delete zip file and figma folder.
now install figma.
good luck
