Conditional "Change to" not working as expected
Brandon_Paterak
Hello,
Wasn’t exactly sure how to tag this as it may be a question or feedback so bear with me.
I have a voting component which can be one of two variables inactive:
  • Inactive & Empty(String)
  • Inactive & Filled(Number)
But a single variable when active:
  • Active & Filled(Number)
My interactions:
  • Tap Inactive & EmptyChange to Active & Filled
  • Tap Inactive & FilledChange to Active & Filled +1
  • Tap Active & Filled (=1)Change to Inactive & Empty
  • Tap Active & Filled (>1)Change to Inactive & Filled -1
I’ve set two local variables #Vote Count = 0 & T Vote Count [Empty] = “Vote”.
Moving from inactive states to active state works fine for both cases, but returning to inactive state conditionally is where I’m running into issues.
Currently I have it set to TapChange to Inactive & Filled & Set Variable #Vote Count - 1. But attempting to add the conditional if #Vote Count is equal to 1 Change to Inactive & Empty is not allowed.
It will give me the option to do this, but attempting to toggle props does not work.
Any ideas?
Brandon_Paterak
Wanted to post an update if anyone is running into a similar issue,
A work around to get this to work as expected.
I’ve added a conditional to Inactive & Filled After Delay (1ms) IF #Vote Count = 0 Change to Inactive & Empty
WillBarrow
I’m having a similar problem where I use a conditional on click inside my interactive component to check the value of a variable and change to a variant. I am able to select the Change To action, but the dropdown listing my variant options will not keep my selection.
  • August 18, 2023
