Additional folders needed for path when running build property in manifest.json
  • March 23, 2021
  • 938 views
Gavin
I’ve recently tried to use the build property of the manifest.json file which can execute a file when the plugin is published.
Unfortunately, when I try to publish the plugin I get the following error.
Build error: env: node: No such file or directory Path was: /usr/bin:/bin:/usr/sbin:/sbin
manifest.json
    "build": "./bin/build"
bin/build
#! /usr/bin/env node
console.log("testing")
Upon further investigation, I can see that node gets installed by default under /usr/local/bin. Also if you use any version managers it could be installed somewhere else completely.
From what I understand on a Mac /usr/bin, /bin, /usr/sbin and /sbin are all protected by System Integrity Protection. This restricts a user by default from making changes to these directories and it’s generally not advised to not to disable it. Generally, customisations should be made in /usr/local.
I believe this is the reason why it is not working for me.
Does anyone have a suggestion to get around this issue?
Additionally, for Figma it would be great if Figma could look for the user’s $PATH or at the least add usr/local/bin as a directory to look in for executables.
Gavin
  • Active Member
  • March 23, 2021
I’ve just found the following that mentions Figma are aware that “the desktop app currently doesn’t set the PATH environment variable correctly”.
figma.com
Workaround
As a workaround, I’ve followed the advice in the article above that mentions prefixing with an absolute path.
"build": "/usr/local/bin/node ./bin/build"
Although this is not ideal if you’re sharing your library with others who may have a different path to their node environment, so that’s just something to bear in mind.
