0px layers now take up 1px space with Auto Layout
Show first post
SachInteractz
Hello All,
I am also experiencing the same problem with Figma’s latest desktop application. Autolayout recognizes zero frames. My goal is to create a strikethrough text effect using the zero-height/frame hack.
Here is what’s happening
Any help would be greatly appreciated
Sachin
tank666
  • 4873 replies
  • June 13, 2022
@SachInteractz, you are using zero-frame incorrectly. And in general, it is no longer necessary to use it in your case. Just select the line and set its absolute position.
Bruno_Garcia1
Hi @SachInteractz,
Like @tank666 said, I think you’re using them wrong:
  • Using a 0 frame in Height on a Horizontal auto-layout… In this case, you would actually need/want to use a 0 width frame. But like @tank666 said, you don’t need to use this technique anymore, you can just use absolute positioning 🙂
SachInteractz
Thank you @tank666 and @Bruno_Garcia1 absolute positioning is the best approach here.
SachInteractz
Hey, I was just digging throughAuto Layout Tips & Hacks by @Gleb and found that in his strikethrough example he is also using a zero-height hack. When I copied the same frame and pasted it to my file the auto layout broke as it recognized zero-frame.
Could anyone explain this to me?
Sachin
SachInteractz
One can use zero-height in a but the direction has to be vertical.
tank666
  • 4873 replies
  • June 14, 2022
Your problem is that you are using Auto Layout’s horizontal direction instead of vertical.
  • 4710 replies
  • June 14, 2022
You need to set Auto Layout direction to Vertical. To understand the zero-height frames better watch my Config talk:
But you don’t need to use zero-frames anymore since auto layout now supports absolute position.
SachInteractz
Yeah Thanks, @Gleb, and @tank666 you guys are awesome
  • July 14, 2022
