Pressing Control + Middle mouse button (third party mouse) on Mac activates right click instead of pan
Ante_Susic
I want to quickly change between pan and zoom and vice versa. On my PC I do this using middle mouse button and scroll wheel whilst holding Ctrl button (I don’t disengage Ctrl). The problem is, for some reason on my M1 Macbook Air when Control + middle mouse button (third party mouse) is pressed, this combo acts as right click on canvas, ie. a drop down menu appears with options for “paste”, “unlock all objects”, etc… My workflow and speed is severely hampered this way. I always have to consciously think to depress Control every time I want to switch from zooming to panning. It’s counter-intuitive and really annoying.
Does anybody have the same experience? If so, is there a solution? Is it a Figma bug, OS bug, or maybe I should reprogram my mouse in some way?
Thanks!
Best answer by Phil_Larsen
What third party mouse do you use?
On Mac I believe it defaults to doing a right click when you press CTRL and click.
I use the to toggle zooming in/out. Still needs to be pressed to engage that function, otherwise the mouse wheel moves vertically.
I like using though because I can easily press and hold space bar to enable panning with the hand tool.
Phil_Larsen
  • Active Member
  • 130 replies
  • July 26, 2022
Ante_Susic
  • July 26, 2022
Wow, that solves the problem! I didn’t know Command also engages zoom! Thanks!
I’m using a cheap Logitech until Razer Viper 8KHz arrives… I’ve bought MX 3S Master but returned it immediately due to scrolling issues on my PC…
Phil_Larsen
  • Active Member
  • 130 replies
  • July 26, 2022
Glad I could help!
