AEUX plugin error - manifest.containsWidget
  • November 4, 2022
  • 4 replies
  • 1125 views
Arjun_Kumar1
Hi there, my AUEX plugin stopped working. So, I tried installing it again and this error shows up:
Manifest error: Expected “manifest.containsWidget” to have type true but got undefined instead
tank666
  • 4859 replies
  • November 4, 2022
Have you tried importing the plugin’s manifest.json into your development widgets?
Arjun_Kumar1
Yes! This error comes up when I do that!
tank666
  • 4859 replies
  • November 4, 2022
Why are you importing it as a widget if you need to import it as a plugin?
longzhiw
  • May 17, 2023
You might have mistakenly imported the plugin’s manifest file as a Widget. The correct path to import the plugin from the manifest is “Plugins” → “Development” → “Import plugin from manifest…”. Please double-check and follow the correct path to ensure the proper import of the plugin.
