New Toolsbar feedback
  • October 17, 2024
  • 25 views
Michele_Pella
-Would be nice have the possibility to stick it to the edge. I find the new floating one distracting.
Also, that gap between the new toolbar and the border of the window is a waste of space. The risk to click something in that gap for mistake is higher.
When you move the mice for select a tool, you often uses the border of the screen as reference for target the button with the cursor. Dunno if I well explain what I mean… basically, when you have a wide movement of the cursor to do, usually you naturally hit the border as first, fast, movement, then you adjust the cursor with a precise movement and hit your target.
-Why not have the possibility to have it back on top, as an option?
-These tools are now extremely small and squeezed too much for who is working with shapes daily, previous ones were easier to use. Which is the logic of have elements options in the sidebar, where values are managed?
Why not have them back in the same bar of the toolbar? Somewhat like this?
Thanks for reading!
  • Figmate
  • 1942 replies
  • October 17, 2024
Hi @Michele_Pella, Thank you for sharing your thoughts! I appreciate you sharing screenshots.
I have noticed that others in the community have also suggested similar idea here, so I will combine your post with theirs to gather all the similar feedback in one place for better visibility.
Thank you once again for your valuable input!
  • Figmate
  • 1942 replies
  • October 17, 2024
A post was merged into an existing topic: Allow us to dock/move the new UI3 toolbar
