Figma slows down in Browser and App
Till
Unfortunately, it is currently not possible to work with Figma under Mac OSX Monterey. I have tried the solutions from the different posts, but unfortunately without success.
No matter if I work in the browser or in the app, it takes forever until something is selected, copied, pasted or modified. My file contains a component library and all components are aligned with Auto Layout. Is there still no solution for this problem? Mac Book Pro, M1 Max, OSX Monterey 12.4.
Sagar_Siwach
Could you share the screenshots of the file, or if you can share the link of the file. I have worked with files with almost 85 Pages having around 120+ Frames Each with UHD Photos and SVG Patterns as background. It takes 3 - 5 Mins to load for me, 9 - 11mins if opening after clearing the cache but once it opens it does not create performance issues.
Till
  • 4 replies
  • June 3, 2022
Hey Sagar,
thank you for your reply. The file himself is difficult to share. It is client project. I duplicated the component lib for you. i hope that helps. maybe i can share you the original file in pm. but i tried some different huge figma files and i have the same problem.
Figma – 3 Jun 22
Sagar_Siwach
I’m on a 13" MPB with M1, I was able to open this in 24 seconds on web and 31 seconds on the App. I believe the problem might be with the installation. I have an extensive tailwind lib that has almost 25 - 30% more volume and I’m able to interact with it on a daily basis without any visible lag or bloat.
Have you tried clearing cache of your Figma app?
Till
  • 4 replies
  • June 3, 2022
yes - but for me it didn´t solve the issue. do you use 114.6.1? (Figma Version)
