In figma, it is currently not possible to persist certain compository styles without having to think of all the possible use cases before and putting them in there, or to provide a component just so that it can be used as a reference, a starting point. The reason for this is that once a layer is in a component, it cannot be replaced, removed, multiplied or reordered. This makes sense, but limits what a component can do.
Examples
Buttons that are capable of showing any icon.
The Icon can only be replaced by a different icon of the same size or the same parent component (icon/*). Meaning, that all icons that are available need to be thought of before. This breaks the components capabilities, because it all of a sudden needs to be aware of the icons it can display.
Text-Content
Content that consists of a variable structure of headlines, paragraphs, lists, quotes, etc. Designing a Template for a view that will receive content from, for example, a CMS is impossible as a component, because we cannot reorder or add individual layers in component instances.
Possible Solution
Let us define variable content containers in components, that can receive any other layer in an instance. This way, we can author components with variable content in mind but still retain the ability to lock certain constants.
Let us reorder layers in component instances that exist in an auto-layout context.
Being able to reorder layers within a component (perhaps within certain restrictions, such as only within designated autolayout containers) would open up a host of useful possibilities.
I have this problem too, typically when icons do not fit a square. One trick I am making is to have several options embedded with auto layout frame. Then I can show/hide the one I need without creating a separate variant of the same component. But it is very tedious to maintain and easy to break.
However I do not see how you propose these “define variable container” will work. The issue right now is that at some place there is an instance with fixed width and hight (and constraints). And it is logical that it preserves its fixed size up the hierarchy.
@tank666 thanks a lot for this tip! It seems like the core here is to wrap all icons in Auto Layout frame and set as variants. My only problem with your sample file: I cannot recreate it in Figma How did you manage to create a frame of zero size (w=0,h=0)? (one that holds a text)
Icon components don’t need to be combined into variants. You need to add Auto Layout to the component with “Hug content” settings, and set the icon layer (eg vector) to “Fixed width” and “Fixed height”.
To create a frame with zero height and/or width, just write .001 in the appropriate fields.
This idea is super powerful, and goes way beyond replacing and reordering single layers. If you can make an empty variable-content frame within a component, you can componentize container designs and page frames. Maybe this conversation, and the original statement above doesn’t quite advertise its strength enough! May need to make a new thread!
I really believe that if more people had some interest in this as well, it might have gotten more than just four upvotes. Unfortunately there doesn’t seem any interest in bringing Figma’s capacities closer to basal mechanics of the web, neither from the people using it, nor from the people developing it.
If I understand what you’re saying correctly, I think this will be really powerful for creating slide presentations with figma, where you have a set of basic slide components, but want to swap out images on a per-slide basis.
