Use a component as a repeating background
  • March 26, 2021
  • 8 replies
  • 7819 views
Tyson_Rosage
I’ve created decorative patterns with nested components and auto-layout to produce the repeating and spacing and it causes terrible performance issues which is understandable given their complexity and scale. I’ve attempted to remedy this by flattening the output as large vector shapes thinking this would to reduce the computational needs to render them with auto-layout. Unfortunately, this hasn’t helped all that much. In any file that uses these large vector shapes I find that as soon as I select a page that contains it Figma freezes up and panning around the document is very difficult (pretty much unusable with auto layout).
I’m aware I can produce a similar effect using and image fill with tiling on any shape or frame but this is limited to using raster graphics as the source. Aside from the fixed resolution of raster graphics, not having the ability to set different fill colors to my patterns is another downside to this solution.
Ideally I’d be able to use a component as the source for a tiled background so it would allow for adjusting the fill color of the component and (in theory) require less resources to render. Currently I’m making a huge vector shape inside a frame with content clipping to make it seemingly “infinite” in size but proper tiling of a background would offer true infinite scaling to the pattern.
Here’s a link with both the auto layout and flattened implementations. To demo the performance issues I have two pages, one for each implementation where you can see how when there are 12 instances of these patterns performance really suffers. In the case of the auto layout implementation, simply trying to duplicate the auto layout frame takes about 4-5 seconds.
Figma – 26 Mar 21
Creating scalable repeating patterns across your designs seems like a pretty common need. Being able to do so with vector objects and the flexibility that comes with that seems like a really powerful feature. I’m curious to learn how others have addressed this issue or if my use case is nutty.
lil_ro
  • March 29, 2021
As a newer Figma user, this was an immediate pain point. Definitely need a way to use components or vector shapes as fills to create seamless patterns.
Exporting to bitmap and then using that bitmap as a fill is just so inefficient. 😩
Timj
  • March 30, 2021
I’d agree bitmaps work but is a bit tedious when refining a pattern. But to do that I just make a test grid of a pattern components so I can refine the pattern in vector/components and then when happy rasterise it. I use a plugin to easily create a grid of components. The rasterisation makes a big difference to the final look of the pattern so if you are designing vector patterns that will be raster make sure pixel rendering is turned on.
Ricardo_Desirat
Hi
It would be great to make patterns/tiles with vectors.
At least, being able to use a SVG as an image (in Tile mode). Uploading it or even copy/pasting it - since Figma is able to copy/paste SVG code.
And a way to preserve the Settings (exposure, etc). Maybe with 2 new ones: vertical and horizontal gap.
Or as an Effect…?
Thanks
Ricardo_Desirat
Hi @Tyson_Rosage
My previous reply was moved here by a Figma moderator because I’ve created one called “Vector Patterns / Tiles” which is similar. I haven’t previously seen your post, probably because I was focusing on being a vector not a component.
In order to not loose more similar ones, what do you think on adding to your title more keywords so it gets to more people?
And let’s hope Figma gets there someday 🙂
  • November 3, 2023
Thanks for the feedback!
We’ll pass this onto our team for future consideration.
Denislav_Prayer_Dimov
SVG as a tiled image would be such a QoL update. Please Figma overlords, give us this option
Stu_Smith
  • September 18, 2024
Copy how Adobe XD did it. Now that it’s a dead product. It was intuitive and useful.
Kelvin_Lin
  • October 18, 2024
This would be great for multi-brand/theme design systems. Our team is using colours with different opacity in different modes depending on the background. 1 less thing our devs need to custom code!
It’s frustrating to have the file hang for over 2 minutes, giving no sign whether it’s going to freeze indefinitely, or eventually apply the colour variable to the tiled SVG.
