I use percentages in a project for the letter spacing. I can’t use variables to achieve this value. It always defaults to pixels.
I have two buttons and they have same animations. I want to first one has same transition like the second one. The first one has hard transition on corner. I'm confused. You can check from here
I’m trying to make a basic plugin to edit the contents of a text node: (async () => { console.log("1"); const node = figma.currentPage.findOne((node) => { return node.name == "TARGET_NODE"; }); if (node != null && node.type == "TEXT" && !node.hasMissingFont) { console.log(node.characters); await figma.loadFontAsync(node.fontName as FontName); // hangs here console.log("3"); node.characters = "SUCCESS"; } else { console.log("4"); }})(); The code runs fine and finds the right node, but it hangs indefinitely when I try to load the font with the error “there are still font loads in progress. Please ensure closePlugin is not called until after the font loading has resolved.”. I’ve tried multiple fonts including basics like Times New Roman, but it can never seem to successfully load the font. I saw a similar question posted a couple years ago but it didn’t get any traction: I’m definitely not a typescript expert, am I missing a step somewhere?
This auto-layout frame is a child/inside a basic frame that I should be able to move things around in. How the heck do I turn this off when I hover over to click and drag. all I want to do is drag the group/autolayout over a bit manually and arrows in this small space are producing too large of a move. this comes up for me a ton and it’s insanely annoying. I can’t click and drag without it also changing the auto layout spacing. if I want to change that I will go to the tool sidebar and do it myself. I don’t need this pink stuff trying to do it for me just because i’ve hovered over it. Also, FYI - I couldn’t even screengrab it through the OS, because this literally happens on hover, so I snapped it with my phone - hence the bad photo, apologies.
Hi folks! I used some components from other files in my project, and even though I removed them, I still see some Variables available in the “Page → Modes”. They are not available anywhere else. It doesn’t affect the project; when I select one, change the page, and then return to it, that mode is selected. I checked my file, and nothing leads to the other file anymore – no styles, variables, components, etc. It seems like a bug, and I see some variables pulled from another file, but can I remove it somehow?
Our design system leverages mix blend modes for hover states so our icon buttons appear on any background color and remain accessible, without needing separate hover–on-primary, hover–on-secondary, etc tokens. We use multiply for light theme, and screen for dark theme. It would be really awesome if we could apply blend modes directly to the color variables, OR support blend modes as variables in general. Our current work around is to apply the blend mode directly on each component variant, but this requires us to define separate light and dark theme variants. would be great if we could use variables here to have it automatically switch between light/dark.
Figma is automatically adding in the Apple UI Kit, even though this library is NOT attached to the original file I’m making a copy of. ORIGINAL FILE DOESN’T HAVE THE LIBRARY COPY HAS THE LIBRARY ADDED It even adds it automatically to NEW files too? How can you stop this madness? There isn’t an option under the UI Kits to add/remove or stop this?
Over the past week, I've been having a problem exporting images. Some parts of the text or frames are shifted by a few pixels, as if they were cut out. At first, I thought the problem was with the font, but it turns out that this problem occurs with any font. I tried all methods, but the only solution I found was to shift the text and frames by a couple of pixels. Has anyone encountered a similar issue and knows how to resolve it? The text and frames have integer values without fractional parts and are tied to the pixel grid. Changing the file type to JPEG or PNG does not help either.
Figma MCP server worked great with VS Code version 1.101.0 but in version 1.102.0, microsoft has moved MCP configuration to a new file named mcp.json instead of previous settings.json file. After doing all the configuration, the Figma MCP server tools do not show up under tools and the agent is unable to use Figma MCP server. Has anyone had any luck with this version? Can Figma team please validate and update documentation for Figma MCP Server setup?
Can you share a library from one organization to another without transferring it and making it public?
Previously, it was possible to copy the image used in the Fill property of one frame and paste it into another frame’s Fill. However, this functionality seems broken or removed in recent updates.This was especially useful for quickly reusing image fills across components. Currently, I have to export and re-import images, which significantly slows down workflow.Please restore or support this functionality again.
Since Figma Make became publicly available, I’ve noticed a significant drop in performance and overall intelligence. I’m not sure if it’s a coincidence, but I no longer see the “Claude Sonnet 4” label next to the prompt area. Everything I try now leads to poor results. Just yesterday, during the beta phase, the AI was much more capable and consistently delivered great outcomes. Today, I’m stuck for hours on simple tasks that were handled effortlessly before. Anyone noticing the same?
I can no longer copy an image from one Figma frame to another. If I want to replace an image I usually click into a frame, open the fill so I can see the image thumbnail, then copy and paste it over an existing image, then delete the old image underneath. This function no longer works, meaning that replacing images is going to take much much longer.
Team, Why can’t I use a component set as an overlay and specify the variant I want to choose? Friends? Please. Otherwise, I have to make an instance that just sits there strictly for overlay. Same thing with navigate to, really. Disorganizes the file and makes it “heavier” than preferred. Please, fix this.
We host the web page in figma.site servers , but i want to host my own html files in my server ? how can i get these files..
I’ve created a prototype which has a few flow starting points for different user testing task scenarios. I typically ask the user to click on the sidebar in prototype mode to jump to the different starting points. I have buttons in my prototype which are positioned center-bottom on the page. When users try to click on them, the “previous frame” and “next frame” buttons from the Figma UI appear and get in the way. If I hide the Figma UI, it gets those buttons out of the way, but also hides the sidebar. Is there a way to hide the “previous frame” and “next frame” buttons but keep the sidebar visible?
Find answers, learn more.
