The icons inside my button instances aren't inheriting the colour token set in my main component
  • August 7, 2024
  • 7 replies
  • 636 views
Evaluz
Hello community!
I have a question regarding colour tokens and components (it has been driving me nuts for days now!) every help is welcome.
So, I have an icon/button component that has the following variations:
  • Icon left or right
  • Primary, secondary or tertiary
  • Disable, Enable, Hover, Click
I’ve structured them like this:
So far, so good. I never had an issue with them until I started applying colour tokens to the icons.
What happens is that whenever I swap the “+” for another icon, the color token value assigned on the main component does not apply to the instance.
Here is an image for you to see what I mean:
The button on the left is an instance with the proper values, but whenever I swap the icon, it changes colour to the value assigned in the icon page.
As you can see, this also happens for the “disable” status.
Now, my icons seem to be generally OK?
I am keeping the “icon/” structure and name every vector as “Vector”.
What I thought could be happening was that I added color tokens to the icons in the icon file
Screenshot 2024-08-07 at 17.36.24
BUT I tested with a random HEX color in the icon from the icon library and I still have the same issue in the components. 🤔
So, I wanted to know if any of you saw another issue that I haven’t?
Thanks in advance!! 🙏
Best answer by Evaluz
Update:
The error was on the naming of each flattened vector.
At first sight is hard to see, but some icons had a space after the name: 'Vector ’ instead of ‘Vector’.
If you’re facing a similar issue, you’ll have to check each icon, one by one to make sure you don’t have any spaces on your names!
KennLucas
  • 224 replies
  • August 7, 2024
This is an ongoing issue in Figma and many people have different opinions and fixes.
You might want to do some searching and research on similar issues to see varying thoughts and form your own way of trying to fix it.
There are folks that insist it is as simple as making sure every icon and nested object is named exactly the same. I have had terrible luck trying this and I just get angry.
Personally, I put every icon in a UNION. This is a little difficult to get used to because a union will hug everything and make you mad because you want it to be a set size. To fix that, put your icon in a union (you kinda have to do two icons to apply a union, then delete one)…put the union in a FRAME. Apply constraints or auto layout to the frame and set size on that. It is easy…but tedious.
APPLY YOUR COLOR SETTINGS TO THE UNION, not to the nested icon.
The Figma help has decent info in explaining unions. But it takes some effort to wrap your head around it for some of us.
" * Union selection: Union combines the selected shapes into a boolean group. If the objects overlap, the new shape’s outer path consists of the composite of its sublayers’ paths minus any segments that overlap. The stroke would then be applied to that outer path ignoring any path segments which overlap each other."
https://help.figma.com/hc/en-us/articles/360039957534-Boolean-operations#:~:text=Union%3A%20Union%20combines%20the%20selected,segments%20which%20overlap%20each%20other.
Google around for Figma Union Hack to find a lot of info.
https://www.figma.com/community/file/1308188795212541398
KennLucas
  • 224 replies
  • August 7, 2024
If you want to post your file, I can make you an example and send it back.
Evaluz
  • 4 replies
  • August 8, 2024
Oh boy! That’s a long thread.
Thank you for sharing those references with me. I’ve read their fixes and I tried those that I haven’t tried yet.
Here are my findings:
  • Keeping the same name (vector, icon) on the layer for color override isn’t working (current state)
  • I tried changing all the icons to another color and then assigning the “original colour” back, but it didn’t work either
  • I did a “union” test with a single icon, but I think that I didn’t quite get what the users were suggesting? I am not sure that I’m following the suggested structure (?)
I’d be very grateful if you could look at my file and see if you can spot the hack. I moved my components to this new file so feel free to move and modify what has to be done.
Button File.fig (185.0 KB)
Thank you for your help.
KennLucas
  • 224 replies
  • August 8, 2024
It is literally shorter than your initial ask thread.
Evaluz
  • 4 replies
  • August 13, 2024
Oh, I was referring to the threads that you shared (the answers make them a long read).
I just realised that my writing might have sounded like a complaint but it wasn’t 🙂.
I am grateful for the help on pointing me to the possible solutions to my bug.
Thank you.
Evaluz
  • 4 replies
  • September 3, 2024
Update:
ferdinand3
Maybe you could just change your tokenization. It would be Best practice to use one local variable called Button/Font/Hover/”Color” and Connect both colors to this. You could then reffer another token „Font/Color/”Color”.
Thats a different approach of connecting colors to different tokens.
