The grid system is not visible in dev mode
Is it possible to improve the part where engineers cannot see the grid system I used when the design is switched to the dev mode?
JandeSterke
One of the most important things I want to see in dev mode.
dennsi
  • 256 replies
  • June 27, 2023
Yep that should be included again ASAP
Ryan_52
  • 382 replies
  • June 27, 2023
Hi, thank you for requesting this. It has been passed along to our engineering team.
It’s really uncomfortable. I don’t use only CSS flex, I use CSS grid a lot, and I tend to work in integration with layout grid. Please solve it quickly.
@Mudi_Zheng … if you have the grid for page in Design mode active and switch to DEV mode, the devs will only see the grid, if he/she activates the grid view with “shift +G”
well it is more a work around 😉
Rebekka_Karrengarn
we also have the same issue - our devs need to have the same toggle as in design tab → so they also can see 12 colums (auto) settings - whenever there is no specific grid applied.
Today via this mentioned work-arround (Shift+G on mac) it is not possible to toggle this „12 columns (auto)“ grids that can be revealed with a hit an an eye-icon in Design Tab
  • January 22, 2024
