tallneil
Active Member
May 9, 2023
Reset text style to default?
  • May 9, 2023
  • 7 replies
  • 2618 views
Is there a way to easily reset a text style to default? When I create a new text field, it usually inherits the most recently used properties - including font family, weight, letter spacing, case, etc. This isn’t always the desired behavior, and it’s tedious to change each property 1 by 1.
Ioana_Gutau
August 26, 2023
I was also trying to find an answer to this question, as i could not find any way to reset the text to default in the current file. The ultimate solution i found, was to open a new file and paste the text there, then copy it in the current file.
Are there any other ways? This is a very easy thing to do in adobe illustrator, just click and type 😕
Naresh_Ugaonkar
October 12, 2023
I am facing the same issue have you found any solution to this yet?
Ben30
February 3, 2024
Also here with the same question. Would like the option to reset text styles back to default.
Oskar_Lewicki
March 21, 2024
I’m looking for the same functionality. It would increase productivity a lot.
John_Saunders
May 21, 2024
For line height you can type into the value box the word ‘Auto’ this should reset back to default. For letter spacing and paragraph spacing set value to ‘0’ 👍🏼
tallneil
tallneilAuthor
Active Member
May 22, 2024
@John_Saunders you’re right, the user can reset each text property one-by-one. But this can be very tedious when you consider all of the text properties in addition to the ones you mentioned: alignment, decoration, case, etc.
I’m currently working on a Figma plugin that will address this issue!
Joshua_Butts
November 19, 2024
@tallneil Did you ever make that plugin? I’d love to try it out.
