Hmm that is weird. I can’t tell what’s wrong from the video. If you can share the file I may be able to find something but I don’t know.
Unrelated to this issue: this toolbar in the middle of the screen is killing me. Did you know you can put it to the bottom of the scroll screen and set constraints to Bottom in order for it to stick to the device bottom? This way it won’t cover any content.
That’s because there are two frames with the same name stacked on top of each other, you probably duplicated them accidentally. So you are changing the top frames while the prototype probably works with the frames at the bottom which were created first.
Hi, I’ve the same issue where the prototype doesn’t update after updating master components. I’ve already published the changes, updated the page, and the component in my design file links to the edited master component - it just doesn’t show the changes to the master component even when I reset all overrides.
