How to copy and paste text from Word documents has changed. I’m having trouble pasting into text boxes in particular. When I copy and paste text from Word it appears as an image in Figma. I have to paste as an image using CMD+V then repaste with CMD+SHIFT+V for the text to paste into a box. Has the way you copy and paste changed in Figma recently? It seems this little difference is adding quite a lot of time to my workflow at the moment.
I think the "contact us" function is very poorly designed and has caused me a lot of trouble. After submitting my feedback, such as a request to modify invoice information, I only received a toast message saying "figma will contact you soon". However, I have been using figma for 3 years and I don't know how to contact you. Until today. I think you should provide us with a way to contact you, such as a link on the webpage. After confirming, the pop-up window should disappear. Otherwise, it will cause a huge and unnecessary workload for customer service. I hope you will seriously consider this。
When I copy any Figma frame using Cmd+Shift+C (copy as png), it gives a message “copied as png” but when I try to paste it in google slides, it doesn’t work. As if there’s nothing in the clipboard. Tried clearing the clipboard still doesn’t work.
Hi, I tried to update my simple Plugin, which I originally added back in 2022. Unfortunately, I got an error which is blocking the update. I also noticed that when I click on the “Permissions” tab the dialog box closes right away. So I don’t know if there is missing something.I also don’t use the E-Mail address anymore, which I added back in 2022. I have no access to it anymore. Instead, I would like to change to the one I use in my account. Any idea what is going wrong?Thanks, Danny
I cant click in this blank area to apply fills/strokes/effects etc, i used to be able to but now i have to click the plus. it takes a little longer to navigate there which is a bit annoying, is this a new thing or a bug?
Hi! Turning off “snap to pixel grid” in a Figma Design file no longer changes snapping behavior when dragging frames around. Whether this feature is turned on or off, a dragged frame still snaps to each pixel, no matter how zoomed-in. Note that some other objects (e.g., vector objects) still respect this setting. It’s just an issue with frames, components, and component instances. Note that If I group the frame, I then can drag the group to any sub-pixel location. I’ve restarted my machine, restarted Figma, checked for updates, reloaded tabs, tried it in other design files. Tried it in the client, in Chrome, and in Safari. Same problem. Can anyone else replicate this?
I'm encountering an issue with the Variables API endpoint when attempting to export local variables. The endpoint returns all remote variables from shared files, making it impossible to export only local variables. Current Behavior: The endpoint returns all remote variables from shared files Unable to filter or export only local variables Receiving a 400 error with "Request too large" message Error Response: { "status": 400, "error": true, "message": "Request too large. If applicable, filter by query params." } Technical Details: The error message suggests using query parameters for filtering However, the endpoint documentation doesn't list any available query parameters The endpoint lacks pagination capabilities This limitation makes the endpoint essentially unusable for files with many variables Expected Behavior: Ability to export only local variables Support for filtering variables (local vs. remote) Pagination support for large variable sets Impact: This issue significantly impact
I hope to add the function of path gradient, which is very useful for logo design.
Is it just me or are the text search buttons in FigJam (when searching via Ctrl+ F shortcut) behaving exactly the opposite way from what to expect?To illustrate, this screenshot shows what I am referring to: When clicking on the “down” chevron, I’d expect to go to the next search result (3 of 57). Instead, what happens is FigJam jumps back to the first search result (1 of 57). Likewise, when clicking the “up” chevron, I’d expect to get to the previous search result - instead, FigJam navigates to the subsequent one. I cannot see how this would make sense, as intuitively, I would associate a downward pointing chevron button with “next” and an upward pointing chevron with “previous”. It seems to be a bug - please fix!
Hello, I had several issues regarding transferring ownership. According to the free plan, only two people on the team have permission to edit. So had removed other team members so there are only two members in the 'team project;. I was still unable to transfer the ownership to the other or edit so I have upgraded to 'professional'. Neither of my member and I can edit or do anything about this file which must be editable since I have upgraded my plan. The admin who created this team project is no longer with us, so we cannot reach out to the admin. Please help me.
Hi!I've recently run into a strange issue when exporting frames from the Figma desktop app (Windows). Some slides/frames export with black bars on the edges (top, bottom, or sides) - but only in certain cases. Here's what's happening: Everything looks totally fine in the browser version - no black bars there. The issue only affects some frames, not all. In the editor, the frames look perfectly normal - the black bars only show up in exported images. I’ve tried: Reinstalling the desktop app Clearing the cache Making sure all layers are aligned to whole pixels Removing shadows and effects that might bleed outside the frame Exporting in PNG, JPG, and SVG — same result Has anyone else run into this? Would love any ideas or workarounds. I’d really appreciate any help 🙏 Hope I explained it clearly English isn’t my first language, so I hope it all makes sense! 😩
Everytime I leave Figma window to go to another window, I get this “New available font: Raleway” notifications. Why is this happening? How do i turn it off?
Figma Team, This is absolutely unacceptable. A payment was made from my credit card, without any authentication or prior notification. What’s even more shocking is that I never saved my card details on my account, yet the billing was processed automatically. This is a serious breach of data protection and financial security. What if I didn’t have sufficient funds? What if I didn’t want to make the payment? You cannot just charge users without consent—this is outright unethical and borderline fraudulent. This is completely unacceptable, especially since my card is not supposed to be saved with you. How did this even happen? I demand an immediate explanation and resolution. This level of negligence is beyond disappointing, and I expect a prompt response. I have already sent an email about this issue. I expect a prompt resolution to this matter. Thank you for addressing this issue as soon as possible.
Hello everyone, I’ve created icons, all vector layers with the same name, and every icon has a variant of sizes - small (16px) medium (24)and large (32). They also have round/sharp Boolean property. I’ve created buttons, also with size variants with matching names and sizes. There’s also variant for only label, only icon, left icon and right icon. There’s also instance swap for every icon size. I also have the icon as nested instance. So I take an instance of the button and I change its size, then I change the icon - lets say from “search” to “plus” for example - but if I want to change the size of the button, the instance swap return to its default icon instance. What should I do, or what did I do wrong?
Find answers, learn more.
