Prototype crashes after loading on iPhone, how to fix this?
Thomas5
Hi all,
When I try to view a prototype on my iPhone, it starts loading but after a while it suddenly crashes and shows an error: ‘a problem has occurred repeatedly’. See the attached video.
  • This happens on other iPhone devices as well with this prototype. Other prototypes do work on my iPhone.
  • Maybe an issue with the amount of screens in the file? I created a new file, copied all the screens to this new file; same error occurd. I removed 90% of all the screens and the prototype works. Pressed CMD + Z got all the screens back and same error occurs.
  • All software is up to date.
  • Tried every prototype setting in Figma, but no luck.
  • Removed cookies and other data on Safari iPhone browser.
  • Using an Enterprise account.
Has anyone a clue what I can do to solve this? Need this to work on my phone for user testing.
Thanks in advance,
Thomas
Best answer by Thomas5
Since this issue I’ve had contact with Figma support and their only solution is to reduce the file size. My file was crashing because it was consuming a lot of memory (I had a lot of hidden layers and component/auto-layout structures).
Would love to see this issue fixed, because now it costs me double the work while using auto layout and other stuff while it should reduce my efforts…
p.s. disabling the interactive components feature also helped a lot
Lana_Kinney
Hey!
This is a huge and extremely frustrating problem on Figma, we have wasted $1000’s of dollars on recruitment when trying to remote usability test figma prototypes just to have the paid participant not be able to use it. If your doing it in person the answer is to use Figma mirror on your iphone, it will work well and give you added control to the user testing session.
Yulia
  • 39 replies
  • June 21, 2021
+1 This is a big problem. The same in the desktop browser Safari
yadan
  • June 26, 2021
I have the same problem
franzidesign
I have the same problem 😦
Test device: iPhone 8
Thomas5
  • July 14, 2021
Thai_Lam
  • August 18, 2021
Not sure why but it actually works well on Android than on iPhone. I have experienced the problems before and usually when open on iPhone, it kept crashing and needed to reload. However on Android there was no problem at all.
So if you do usability test with Figma protoype, you can do it on Android for now
Joey2
  • September 30, 2021
Also having this issue, I wish I noticed or tested this on the device before spending days on a prototype. 🥵
Emma_Riley
Same issue here. Please resolve this.
Maria_de_la_Paz_Graziani
same issue!! please fix it
Tamas_Zelizi
Same issue here… We had to turn down our user test because the prototype always crashed on the participants device…
Melissa_Randall
I had the same issue. It’s working fine on my iPad so I think it could be a caching / memory issue on iPhone ( 11 Pro Max ). I closed all my open windows / tabs in safari on iPhone, then restarted the phone. It seems to be working for now, but not sure if just temporary until memory fills up.
I think there is a correlation with interactive components also. It seems that adding ones with hover states creates the issue ( am re-using desktop components, but might try building separate mobile components ).
update… the issue does fix itself by rebooting the phone, but after a while you may come back to it, and it crashes. a quick reboot will fix it. It’s not ideal, but may be a workaround for testing purposes.
update 2… Firefox browser on iPhone seems to be a bit more stable, but still requiries a reboot after a while.
JessT
  • November 17, 2021
Hi all, after about three hours of digging around, I found Loom screen recorder. I recorded myself going through the prototype and then embedded the video in my portfolio. My case study doesn’t crash at this point in time when viewing on my phone. Hope this helps.
Nick_Birkby
+1 this is extremely frustrating. I did not have issues with this before switching to Figma.
Robert_Bye
  • Figmate
  • 46 replies
  • November 18, 2021
Hi all, we’re digging into this problem a bit further. Would any of you be happy to share a link to the file/prototype that’s causing issues so we can investigate?
Thanks!
Ron_Matana
Hi @Robert_Bye i’m dealing with this issue now as well. can i provide you a link too? as you can imagine, it’s rather maddening to spend weeks on a business critical prototype that just won’t work on any iphone browser. i too have reduced file sizes, minimized use of smartanimate (believe i’m following the rules and best practices).
this doesn’t happen on android.
reported here too:
Robert_Bye
  • Figmate
  • 46 replies
  • November 22, 2021
Hi @Ron_Matana if you could, that would be fantastic! Thanks so much
Ron_Matana
gracias @Robert_Bye. believe i shared it via direct message. first time doing so…so lmk if i bungled it.
Robert_Bye
  • Figmate
  • 46 replies
  • November 24, 2021
All received through! Just dropped you a reply to help me get access
Ashok_Kumar_Sivalingam
Hi guys has there been a update for this, please?
Facing the same issue, tried duplicating all screens to a new figma file. Still having the same problem that the prototype is not working on iOS.
Saso_Jakljevic
Hey Robert, I am facing the same problem and can share the prototype link with you. How do I share it?
Maryam1
  • December 4, 2021
Hi @Robert_Bye do you also know how to restart a prototype from a mobile browser? Is there a shortcut we can use?
Emanuel2
  • February 26, 2022
Hey everyone and Hi @Robert_Bye. How far is the progress so far regarding this problem ? I Have the same issues as everyone in this thread. I even tried making all my screens .jpg to reduce loading times and memory issues but it still doesnt work. Like @Thai_Lam already mentioned, on android it somehow works more or less fine, whereas IOS is just loading and then instantly killing the page afterwards. What im curious about is why the figma prototype uses about 5 gb of memory on my Labtop (my Prototype is about 45 slides long) EVENTHOUGH I only use .jpgs and some connections in between.
Robert_Bye
  • Figmate
  • 46 replies
  • March 1, 2022
Hey @Emanuel2 I know it sounds counterintuitive, but converting things to .jpgs will actually make crashes more likely due to images using more memory than vectors.
On Android we are less limited with memory usage compared to iOS, hence why it does perform better.
Emanuel2
  • March 1, 2022
@Robert_Bye I see. Thanks for your answer. When do you think will there be a solution for people with this problem ? especially for users on IOS ?
Robert_Bye
  • Figmate
  • 46 replies
  • March 1, 2022
We’re still actively looking into this, and improvements have been made in the past few weeks as well 👌
