Override Text on Hover not working
Matea_Cumpf
Hi there!
New to Figma, but I did make sure to watch all the tutorial videos and go through forums before posting.
What I’m using:
Figma Desktop App version 116.4.4, on macOS Catalina version 10.15.7
The problem I’m experiencing:
I created a component for a menu item to use in my nav bar, and for the menu item they obviously need to be labelled different. So I created instances on my frame, and then change the text. Noticed that on hover the text change for those instances did not work, changed it within the design file but on the prototype it does not show the changes.
Screenshots:
But on the prototype, the default shows the text changed, but on the hover it goes back to the default text “Menu Item”.
Is anyone else having issues?
Let me know!
Matea
  • November 2, 2022
Your text elements must have the same name in all variants in order to preserve overrides (eg. “label”).
Matea_Cumpf
Do you mean instead of “MenuItem/Default” and “MenuItem/Hover”?
I tried that and this issue is still occurring. On hover the type is still “Menu Item”
Matea_Cumpf
Screen Shot 2022-11-02 at 11.14.21 AM
Here is a screenshot of the prototype.
  • November 2, 2022
Could you share a link to an example file?
Matea_Cumpf
Yes of course; https://www.figma.com/file/1KFbpu7L6N4PnKkhottiat/Untitled?node-id=2%3A17
Really appreciate your help on this!
Theo_Luciano
It’s not public currently, so we can’t view it.
Theo_Luciano
can you update permissions?
Matea_Cumpf
Theo_Luciano
Here’s your problem…
The children of “hover” and “default” need to be named the same.
Matea_Cumpf
OH! In the main component!!
I see, thank you!!
Theo_Luciano
for sure, happy to help!
Actually this caught my eye cause I was struggling with it last month. I wrote an in-depth piece on it if you want to check it out.
https://bootcamp.uxdesign.cc/retaining-styles-when-swapping-instances-within-a-nested-component-figma-201-335d054187d0
Matea_Cumpf
Obviously need to learn more, so appreciate the link! Will check it out!
Thanks again 🙂
  • December 2, 2022
